- To: Venanzio Capretta <venanzio AT cs.kun.nl>
- Cc: coq-club AT pauillac.inria.fr, Bruno.Barras AT cl.cam.ac.uk
- Subject: Re: EApply
- Date: Mon, 08 Mar 1999 18:16:46 +0000
Hello,
> Why don't the existential variables created by EApply get instantiated
> during the proof?
> Unnamed_thm < Apply Rnm.
> 1 subgoal
> (R ?136 p)
> At this point the existential variable ?136 should already have been
> instantiated with m. Why doesn't this happen?
In fact it is: ?136 behaves like a constant equal to m, but it isn't unfolded.
Unfold ?136
wouldn't work for syntactic reasons, and because the script wouldn't work in
another session (the ex. var. number wouldn't be the same).
There is a tactic called NormEvars that unfolds all ex. vars., then you get
the goal you expected (I wonder if NormEvars is in the documentation). Since
any tactic that performs unification may instantiate ex.var., we let the user
doing NormEvars when needed, instead of doing it all the time.
By the way, I believe that NormEvars should rather be a vernac command that
applies to all the subgoals of a proof. On the other hand, it would prevent
us
from writing (Apply Rnm; NormEvars), which in this case is useless since the
instantiation affects a goal which isn't the Apply tactic's subgoal.
Cheers,
Bruno Barras.
e-mail:
bruno.barras AT cl.cam.ac.uk
www: http://www.cl.cam.ac.uk/~bb236/
tel: +44 (1223) 334688
- EApply, Venanzio Capretta
- Re: EApply, Bruno Barras
- Re: EApply, Herman Geuvers
