- From: Patrick Loiseleur <Patrick.Loiseleur AT lri.fr>
- To: "Randy Pollack" <rap AT dcs.ed.ac.uk>
- Cc: coq AT pauillac.inria.fr, coq-club AT pauillac.inria.fr
- Subject: Re: Local Fixpoint definitions?
- Date: Fri, 14 May 1999 10:40:54 +0200 (MEST)
In his message from Thursday 13 May, 1999, Randy Pollack wrote:
> How can Fixpoint definitions be made local in the sense that "Local"
> makes definitions local and "Remark" makes lemmas local?
> Randy
You must use "Local" that creates local constants and "Fix" that
creates anonymous (mutual) fixpoints. Here is an example:
Local plus := Fix toto {toto[n:nat]: nat -> nat :=
[m:nat]Cases n of
| O => m
| (S n') => (S (toto n' m))
end}.
I used "toto" here to demonstrate that this is a bound name and so its
value is irrelevant. But you might want to call it "plus".
Maybe it would be a good idea to add a "Local Fixpoint" command,
symmetric of "Local" w.r.t. "Definition" or "Remark" w.r.t "Theorem".
Best regards,
Patrick
- Local Fixpoint definitions?, Randy Pollack
- Re: Local Fixpoint definitions?, Jean-Christophe Filliatre
- Re: Local Fixpoint definitions?, Patrick Loiseleur
