- To: Steve Stevenson <steve AT cs.clemson.edu>
- Cc: coq-club AT pauillac.inria.fr, info-hol AT jaguar.cs.byu.edu, isabelle-users AT cl.cam.ac.uk, lego-club AT dcs.ed.ac.uk, nuprllist AT cs.cornell.edu, pvs AT csl.sri.com, gopalan AT cs.uchicago.edu
- Subject: Re: Suppose caml or ML had unification ....
- Date: Thu, 16 Sep 1999 18:53:12 -0400 (EDT)
> I'm contemplating extensions to functional languages that
> would support development of formal projects like provers. My analysis
> says that many implementation issues would go away (or at least be
> easier) if functional languages had unification. There was a lot of
> work done on this but it doesn't seem to be in the available
> compilers.
One can change this question to be rather: Should I move my formal
projects (like provers) to a language where unification is supported
declaratively and directly? The most obvious candidate would be
Prolog, but it is a rather old-fashion language by now and does not
support a lot of modern programming concerns (types, modules,
higher-order programming abstractions, etc) and does not treat syntax
very well itself (lacks occur-check, for example).
There is a much more modern update to Prolog called lambda Prolog. It
has polymorphic types, modules, abstract datatypes, and higher-order
programming all as part of its declarative core. It also has a
built-in, logically motivated treatment of syntax containing bound
variables, for which alpha-conversion, correct substitution, sound
unification, etc are primitives. One domain that this language has
shown promise has been the construction of provers. For more on this
language, see http://www.cse.psu.edu/~dale/lProlog/.
There is also a new compiler for lambda Prolog called Teyjus, written
by Gopalan Nadathur (http://www.cs.uchicago.edu/~gopalan/). It
incorporates a lot of new technology described in the recent research
literature that was designed for formal systems: explicit
substitution, lazy substitution, and higher-order patterns (even
higher-order unification). For more on this implementation, see
http://teyjus.cs.uchicago.edu/.
Coming back to your questions more specifically about extension to
functional programming to support formal system development: the paper
below was an attempt to extended ML with support for bound variables
within syntax. (It still relies on matching, not unification.)
"An Extension to ML to Handle Bound Variables in Data
Structures", by Dale Miller. Proceedings of the Logical Frameworks
BRA Workshop, May 1990.
ftp://ftp.cse.psu.edu/pub/dale/mll.dvi
ftp://ftp.cse.psu.edu/pub/dale/mll.ps
ftp://ftp.cse.psu.edu/pub/dale/mll.pdf
-Dale Miller
Department of Computer Science and Engineering FAX: 814-865-3176
The Pennsylvania State University Email:
dale AT cse.psu.edu
220 Pond Laboratory Main Office: 814-865-9505
University Park, PA 16802-6106 USA http://www.cse.psu.edu/~dale
- Suppose caml or ML had unification ...., Steve Stevenson
- Re: Suppose caml or ML had unification ....,
David von Oheimb
- Re: Suppose caml or ML had unification ...., Dale Miller
David von Oheimb
