coq-club - Re: pretty printing
Re: pretty printing
chronological Thread
  • From: Jean-Christophe Filliatre <filliatr AT lri.fr>
  • To: Dimitri Hendriks <Dimitri.Hendriks AT phil.uu.nl>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: pretty printing
  • Date: Mon, 27 Sep 1999 11:42:10 +0200 (MEST)
> How do I switch off pretty printing
> (in particular: and, or & ex) ?
You  can  override the  current  pretty-printing  rules  by new  ones,
following the current ones  defined in LogicSyntax.v. For instance, if
you add:
    Syntax constr
    level 6:
      and [<< $t1 /\ $t2 >>] -> [ [<hov 0>"and" [1 0] $t1:L [1 0] $t2:E ] ].
then A  /\ B will  be no longer printed  as A /\  B but as (and  A b),
which is what you want.
I'm not  a specialist of  PP in  Coq, and I  don't really know  is the
solution   above  is   fully  correct   regarding  the   insertion  of
parentheses. You can read the  reference manual for more details about
the way to define new pretty-printers:
      http://coq.inria.fr/doc/node.2.0.2.html
Best regards,
Jean-Christophe FILLIATRE
mailto:Jean-Christophe.Filliatre AT lri.fr
  http://www.lri.fr/~filliatr
