- From: Claudio Sacerdoti Coen <sacerdot AT students.cs.unibo.it>
- To: Frederic Blanqui <blanqui AT lri.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: A strange theorem (Was: Can I define an equality dependent on another one?)
- Date: Tue, 5 Oct 1999 11:17:42 +0200
On Fri, Sep 24, 1999 at 14:52:13 +0200, Frederic Blanqui wrote:
> > I get
> > Uncaught exception: File "equality.ml", line 0, characters 20213-20225:
> > Assertion failed
> > If this is in user-written tactic code, then it needs to be modified.
> > If this is in system code, then
> > it needs to be reported.
> I think it is due to the fact that the tactics Discriminate or Injection
> have been defined on = and not on ==.
I was almost convinced when I saw this, i.e. a theorem that could be
proved but whose instances could not:
Inductive T : Type := atom : (T':Type)T'->T.
Theorem ok :
(T':Type; T'':Type; t':T' ; t'':T'') ~T'==T''->~(atom T' t')==(atom T''
t'').
Unfold not; Intros; Apply H; Inversion H0; Reflexivity.
Qed.
Theorem instance_of_ok :
~nat==bool->~(atom nat O)==(atom bool true).
Unfold not; Intros; Apply H; Inversion H0.
Error during interpretation of command:
Assertion failed
Hi,
C.S.C.
Real Name: Claudio Sacerdoti Coen
Address: via del Colle n.6
S. Lazzaro di Savena (BO)
Italy
e-mail:
sacerdot AT cs.unibo.it
- A strange theorem (Was: Can I define an equality dependent on another one?), Claudio Sacerdoti Coen
