coq-club - Re:extracting to equality
chronological Thread
  • From: Eduardo Gimenez <Eduardo.Gimenez AT inria.fr>
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re:extracting to equality
  • Date: Fri, 22 Oct 1999 16:42:22 +0200 (MET DST)
> For example, suppose I want to write a program that uses an equality
> on lists of pairs. In Caml, we just use "=", and in Coq we could
> suppose a parameter eq_listpair, but how can these be connected? There
> isn't an identifier in Caml, as there is for eq_string, say, which
> would allow a link, and I'd rather not have to define the (obvious)
> equality by hand in Coq.
Hi,
A possible solution is to axiomatise all your Coq equalities, and then
to map them onto the Caml equality. Example:
Parameter natEq  : (x,y:nat){x=y}+{~x=y}.
Parameter boolEq : (x,y:bool){x=y}+{~x=y}.
Require Extraction.
Extract Constant natEq  => "(=)".
Extract Constant boolEq => "(=)".
Yours,
Eduardo Gimenez.
