- From: Marko Luther <luther AT ares.informatik.uni-ulm.de>
- To: coq-club AT pauillac.inria.fr
- Subject: Re: Re: suppressing types
- Date: Sun, 31 Oct 1999 18:24:19 +0100
Hello,
Dear Ewen,
Can the pretty-printing mechanism be changed to prevent `unnecessary'
types being shown?
A rule for Coq output is that what is printed could be re-parsed as
is. Then, you can avoid `unnecessary' types being shown if a dual
mechanism allow to automatically deduce these types.
No rule without exception:)
Earlier this year I encountered the following problem with the
printing/parsing mechanism used in Coq:
In the trace below Coq (I think V6.24) prints the expression
'(f (c o))' (explicit term '(f N (c o))') as '(f (o))' which is
original of type 'N'. While re-parsing '(f (o))'
the system infers the explicit term '(f O o)' which is of type 'O'.
The source of the problem is an interaction (or confusion) between the
2 mechanism which generates the Implicit Syntax, namely Argument Synthesis
and Coercion Synthesis.
In my opinion this is not just an implementation bug,
but something which has to be analyzed and formalized in greater detail.
Of course the trivial solution to print all terms fully explicit is not a good
choice for a proof development system which wants to be useful.
At the moment I am working on an advanced (partial) type inference algorithm for
our Typelab System (based upon an equivalent calculus as Coq), which
combines Argument Synthesis (including the inference of the type of nil),
Coercion Synthesis and the inference of anonymous type annotations.
Taking Implicit Syntax seriously I have develop a (partial)
erasure algorithm which has the desired feature of being invertible with respect
to the elaboration algorithm (every erasure can be elaborated again into the same orginal term of the explicitly typed language).
While this work is still unfinished, I'd be very interested to hear what
people
have to say on the general topic.
Best regards,
Marko Luther
Trace:
Coq < Implicit Arguments On.
Coq < Variable N:Type.
N is assumed
Coq < Variable O:Type.
O is assumed
Coq < Variable f:(T:Type)(t:T) T.
f is assumed
Coq < Print f.
*** [ f : (T:Type)T->T ]
Position [1] is implicit
Coq < Variable c: O -> N.
c is assumed
Coq < Variable o:O.
o is assumed
Coq < Class N.
N is now a class
Coq < Class O.
O is now a class
Coq < Coercion c:O >-> N.
c is now a coercion
Coq < Check (f (c o)).
(f (o))
: N
Coq < Check (f (o)).
(f o)
: O
Marko Luther phone: +49 731 - 50 24117
Artificial Intelligence fax: +49 731 - 50 24119
University Ulm
mailto:luther AT informatik.uni-ulm.de
D-89069 Ulm http://www.informatik.uni-ulm.de/ki/luther.html
- Re: Re: suppressing types, Marko Luther
