- From: Laurent Thery <Laurent.Thery AT sophia.inria.fr>
- To: "Randy Pollack" <rap AT dcs.ed.ac.uk>, freek AT cs.kun.nl
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: Saturation in Coq: an idea from LEGO
- Date: Tue, 02 Nov 1999 15:24:25 +0100
Hi,
Randy Pollack>> I assume that Laurent was actually looking for a more natural
solution
Randy Pollack>> than "prove it as a top-level lemma".
As a matter of fact I really want some saturation, going from the
hypothesis to the goal.
>Randy Pollack>In LEGO, definitions made when in proof mode are local in the
>context
>Randy Pollack> of the current goal, rather than at top level as in Coq.
This is possible in Coq using the tactic Cut
Cut a0=b0; [Intros Fact1 | Idtac]
Macros definition can make the syntax close to what you propose.
In HOL they also have a tactic "by" inspired by Mizard that is pretty handy:
a0=b0 by THE_TACTIC_THAT_PROVES_A0=BO
It gives a nice declarative flavor to your proof scripts.
>Freek Wiedijk> I don't think Coq has "real" first-class local lets?
You can define one. In my proofs I often use the following constant:
Definition LetP: (A, B:Set) (h:A) ((u:A) u =h ->B) ->B.
Intros A B h H'.
Apply H' with u := h.
Auto.
Defined.
When I want to name an object locally I simply apply LetP.
--Laurent
Ps: The mailing list of Coq seems to be moderated (a message sometimes
needs more than a day to reach the mailing list). An automatic filtering
that would get rid of 90% of the junk email, could be more appropriate?
- Re: Saturation in Coq: an idea from LEGO, Freek Wiedijk
- <Possible follow-ups>
- Re: Saturation in Coq: an idea from LEGO, Laurent Thery
- Re: Saturation in Coq: an idea from LEGO, David Delahaye
