- To: coq-club AT inria.fr
- Subject: Christmas is coming
- Date: Fri, 17 Dec 1999 17:27:12 +0100
I would like to advertise a few tools that I developed to speedup my
work in Coq. They are mostly tactics or commands written in ml, with
a vernacular file attached to make these tools directly available from
Coq.
Here is a summary
* SearchPattern : a more elaborate search command, to see less
garbage.
in http://www.inria.fr/lemme/Yves.Bertot/fine_search.tar.gz
* OnThen : like ";" except that the second tactic is only applied to
designated subgoals.
(available with DebugTac).
* DebugTac : a tactic debugger for large composed tactics
in http://www.inria.fr/lemme/Yves.Bertot/debug_tac.tar.gz
Here is a more complete explanation of these tools.
* SearchPattern,
Like Search, but it uses a patten to decide the theorems you want to
see. For instance you can request to see only those equalities on
type blahblah by entering the command:
SearchPattern (eq blahblah ? ?).
There are a few variants, like
SearchPattern ? = ? outside Zcomplements Zlogaritm zarith_aux.
If you don't want to see the theorems that were defined in a given
collection of files (in this example we avoid the theorems used for
the tactic Omega), and even more useful (nach meine einige
erfahrungen) you can search for rewriting theorems using commands
like the following one:
SearchRewrite (minus (plus ? ?) ?).
Patterns need not be linear: you can express that the same
expression must occur in two places by using indexed existential
variables:
SearchPattern (le ?1 (S ?1)).
will not find the the constructor le_S.
I also have a variant for use inside CtCoq and Pcoq in the future.
* OnThen
This is a variant of the ";" tactic composer. It receives as extra
arguments the list of indices of goals that will be taken care of by
the second tactic.
For instance
OnThen (Case t) (Discriminate) 1 3 5
Will apply the tactic "Case t", then it will apply Discriminate only
on the first, third, and fifth generated subgoals.
* DebugTac
This is a simple tactic debugger for large composed tactics
constructed using ";" and ";[...| ... | ...]". Such large composed
tactics can be very useful for the "Abstract" tactical, but they are
rather painful to debug when an error creeps in (or when the context
changes).
There are two variants to the debugger. The first one is called
DebugTac and will execute an erroneous composed tactic as much as
possible, giving as a report the tactic that was effectively
computed. This tactic never fails.
The second variant is called DebugTac2 and will fail if the observed
tactic fails. When failing it will give a report consisting of:
- the goal at the time of failure
- the sub-tactic that should have been applied on this goal.
Hopefully, the combination of these two tactics should make
debugging large tactics much easier.
Here is an example of use (done with CoqV6.3.1, but the package also
works with CoqV6.3, or CoqV6.2.4).
paprika$ coqtop
Welcome to Coq V6.3.1 (December 1999)
No .coqrc or .coqrc.6.3.1 found. Skipping rcfile loading.
Coq < Require Debug_tac.
[Reinterning Debug_tac...done]
[Loading ML file debug_tac.cmo ...done]
Coq < Goal (True /\ ~O=(S O)) /\ (True /\ O = O).
1 subgoal
(True/\~O=(S O))/\True/\O=O
Unnamed_thm < DebugTac2(Split;(Split;[Auto | Discriminate])).
in branch no 2 after tactic Split
Execution of this tactic raised message
Error: goal does not satify the expected preconditions
on goal
O=O
faulty tactic is
Discriminate
1 subgoal
Unnamed_thm < DebugTac(Split;(Split;[Auto | Discriminate])).
========= Successful tactic =============
(OnThen (Split) (Split; [ Auto | Discriminate ])
1)
========= End of successful tactic ============
1 subgoal
O=O
Unnamed_thm <
I am currently working on integrating these inside the graphical
user-interface Pcoq (error reporting must be done in a different way).
these packages are available from my web-page. I also have versions
of these packages adapted for older version of Coq. Any feedback or
suggestion for improvement is welcome.
Yves
- Christmas is coming, Yves Bertot
