- From: Claudio Sacerdoti Coen <sacerdot AT students.cs.unibo.it>
- To: Hugo Herbelin <herbelin AT margaux.inria.fr>, coq-club AT pauillac.inria.fr
- Cc: asperti AT cs.unibo.it, schena AT cs.unibo.it, lpadovan AT cs.unibo.it
- Subject: Re: A question on positivity conditions
- Date: Mon, 31 Jan 2000 15:29:18 +0100
Thank you for the answer, but I still don't understand it.
> The constant X _occurs strictly positively_ in T in the
> following cases:
> -- T=(X t1 ... tn) and X does not occur in any of ti
> -- T=(I a1 ... am t1 ... tn) where I is an inductive type not mutually
> defined with m parameters and arity of length n, and X does not occur
> in any of the ti but each constructor of I satisfies the weak
> positivity condition after substituting the parameters by a_1 ... a_n
What does "each constructor of I satifies the weak positivity condition
after substituting the parameters by a_1 ... a_n" mean?
Which name should respect the weak positivity condition in
the types of the constructors of I? If it is I (as we understand) then we
could not find an example in which the condition could be false. Moreover,
this example seem to respect the condition but is not accepted by Coq
(reasonable!):
Inductive t : Set := k : (list (nat -> t)) -> t.
Accordingly to your definition, the weak positivity condition must hold on
nil : (list (nat -> t))
cons: (nat -> t) -> (list (nat -> t)) -> (list (nat -> t))
and we think it does (w.r.t. list).
> -- T=(x:U)V and X does not occur in U but may occur strictly
> positively in V.
> The constant X _satisfies the weak positivity condition_ in t either
> when t=[x:T]u and X occurs strictly positively in T and satisfies the
> weak positivity condition in u, or when X satisfies the positivity
> condition (defined as before) in t.
Thank you in advance,
C.S.C.
Real Name: Claudio Sacerdoti Coen
Address: via del Colle n.6
S. Lazzaro di Savena (BO)
Italy
e-mail:
sacerdot AT cs.unibo.it
- Re: A question on positivity conditions, Claudio Sacerdoti Coen
- <Possible follow-ups>
- Re: A question on positivity conditions, Hugo Herbelin
