- To: Christine Paulin <Christine.Paulin AT lri.fr>
- Cc: Pablo Argon <pargon AT postoffice.Cadence.COM>, coq-club <coq-club AT pauillac.inria.fr>
- Subject: Re: Negative to Positive
- Date: Thu, 13 Apr 2000 15:55:18 -0700
- Organization: Cadence Berkeley Laboratories
Christine Paulin wrote:
> This is certainly not a Coq definition (f should not be
> accepted as a parameter because it is used with different instances)
I'm sorry, it was a cut&paste error from a scratch file,
below you could see an executable excerpt.
For example, I should be able to prove:
(t:nat)(Sem (snot (FFalse Signal)) t)
Pablo
In his message of Wed April 12, 2000, Pablo Argon writes:
> Rule semnot doesn't comply with the strict positivity condition
> required.
Error: Non strictly positive occurrence of #GENTERM (REL 3) in
(t:nat; f:(flaexpr Signal))(NNot (Sem f) t)->(Sem (snot f) t)
> I remember that somewhere I read that we can
> transform negative occurrences into positive ones... but I can't
> figure out where.
> Someone can remember me the trick ?
> Thank you all in advance,
> Pablo A.
NB: I use V6.3.1 (December 1999)
Excerpt,
Require Export Classical_Prop.
(* The semantic definition of temporal operators *)
Definition NNot [s : nat->Prop] : nat->Prop :=
[t : nat] ~ (s t).
Definition AAnd [s1, s2 : nat->Prop] : nat->Prop :=
[t : nat] (s1 t) /\ (s2 t).
Inductive FF [s : nat -> Prop] : nat -> Prop
:= FF_n : (t:nat) (s t) -> ((FF s) t)
| FF_pred : (t:nat)((FF s) (S t))-> ((FF s) t).
Implicit Arguments On.
Section SyntaxFlas.
Variable Signal : Set.
Inductive flaexpr : Set :=
Var : Signal -> flaexpr
| TTrue : flaexpr (* syntactic true *)
| FFalse: flaexpr (* syntactic false *)
| snot : flaexpr -> flaexpr
| sFF : flaexpr -> flaexpr
End SyntaxFlas.
Inductive Sem : (flaexpr Signal) -> nat -> Prop :=
semTTrue : (t:nat)(Sem (TTrue Signal) t)
| semFFalse : (t:nat)False -> (Sem (FFalse Signal) t)
| semnot : (t:nat)(f:(flaexpr Signal)) (NNot (Sem f) t)->(Sem (snot
f) t)
- Negative to Positive, Pablo Argon
- Re: Negative to Positive,
Christine Paulin
- Re: Negative to Positive, Pablo Argon
- Re: Negative to Positive, Christine Paulin
Christine Paulin
