coq-club - Re: Refine issue
Re: Refine issue
chronological Thread
  • From: Jean-Christophe Filliatre <filliatr AT csl.sri.com>
  • To: Pablo Argon <pargon AT cadence.com>
  • Cc: coq-club <coq-club AT pauillac.inria.fr>
  • Subject: Re: Refine issue
  • Date: Thu, 27 Apr 2000 11:51:11 -0700 (PDT)
In his message of Wed April 26, 2000, Pablo Argon writes:
>       I'm building a "toy" example using the Refine tactic.
> But  "I loose" the equality l=(cons a l') deriving from the
> case analysis.
> I don't see any "simple" way (without modifying the function
> given in the Refine) to reintroduce this equality in the hypothesis.
Indeed, you need to make that information available inside the
branches. Here is one way of doing it:
Theorem Quick : (l:(list nat))(Acc (list nat) (LgthOrder nat) l)->(list
nat).
Proof.
Fix Quick 2; Intros l H.
Refine
  (<[x]l=x->(list nat)>Cases l of
       nil        => [_](nil nat)
   |  (cons a l') => [h](Quick (Filter (before a) l') ?) ^
                        (cons a (Quick (Filter (after a) l' ) ?))
   end
   (refl_equal (list nat) l)).
and h is your expecting hypothesis (l=(cons a l'))
This is the way both Program and Correctness tactics manage to avoid
that caveat. Notice that it is no big deal: in the general case, you
just transform
     <P>Cases e of p1 => e1 | ... | pn => en end
into
    (<[x]e=x->P>Cases e of p1 => [h1]e1 | ... | pn => [hn]en end
     (refl_equal T e))
where T is the type of e.
Hope this helps,
  Computer Science Laboratory   Phone (650) 859-5173
  SRI International             FAX   (650) 859-2844
  333 Ravenswood Ave.           email
  Menlo Park, CA 94025, USA     web    http://www.csl.sri.com/~filliatr
