- From: Frederic Blanqui <Frederic.Blanqui AT lri.fr>
- To: Asger Alstrup Nielsen <alstrup AT sophusmedical.dk>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: Using Coq to prove properties in a restricted world
- Date: Wed, 5 Jul 2000 14:55:15 +0200 (MET DST)
On Tue, 4 Jul 2000, Asger Alstrup Nielsen wrote:
> At this point, I have the first question:
> Rule R4 is an explicit formulation of the rule: "At most one of A4, A7,
> A8 may be set at a given time.". I'd like to express this as max_one(A4,
> A7, A8).
> Similarly, I have a exactly_one(A1, A2, A3) expression, which states
> that exactly one of A1, A2 and A3 must be set at a given time.
> My first question is: How can I formulate max_one and exactly_one in
> Coq? I.e. I'd like to express R4 like this:
> max_one(A4, A7, A8).
> How do I define max_one to do this?
I have the following propositions but I don't know if it will fit well
with the other problems.
Require Arith.
Require PolyList.
Parameter A : nat->Prop.
Fixpoint atmost_one [l : (list nat)] : Prop :=
Cases l of
nil => True
| (cons k l') => ((A k) /\ (none l')) \/ (~(A k) /\ (one l'))
end
with none [l : (list nat)] : Prop :=
Cases l of
nil => True
| (cons k l') => ~(A k) /\ (none l')
end.
Definition exactly_one [l : (list nat)] : Prop :=
(atmost_one l) /\ ~(none l).
(* rules *)
Axiom R4 : (one (cons (4) (cons (7) (cons (8) (nil nat))))).
(* you can define a more compact syntax for lists if you want
to write something like:
Axiom R4 : (one [(4),(7),(8)]).
see RM chapter 9 *)
You could also try to formalize your worlds as lists of booleans. There is
a module 'Bool' for booleans and a hint base 'bool'.
Require Arith.
Require PolyList.
Require Bool.
Definition world : Set := (list bool).
Definition mynth [n : nat; w : world] : bool :=
(nth n w false).
Definition R1 [w : world] : bool :=
(negb (andb (mynth (2) w) (negb (mynth (1) w)))).
(* xorb is already defined in 'Bool' *)
(* Definition R [w : world] : bool :=
(bigand-to-be-defined (R1 w) ... (Rn w)). *)
(* 'w' is a good world if '(R w) = true' *)
(* then, you can try to check some requirements on good worlds:
Lemma L1 : (w : world) (R w)=true -> (mynth (1) w)=true
-> (mynth (2) w)= true).
Frederic Blanqui.
Laboratoire de Recherche en Informatique (LRI) - Equipe DEMONS
batiment 490, bureau 153, Universite Paris-Sud 91405 ORSAY (FRANCE)
tel:01 69 15 42 35 - fax:01 69 15 65 86 - web:http://www.lri.fr/~blanqui
- Using Coq to prove properties in a restricted world, Asger Alstrup Nielsen
- Re: Using Coq to prove properties in a restricted world, Frederic Blanqui
- Re: Using Coq to prove properties in a restricted world, emmanuel LEDINOT
- <Possible follow-ups>
Jean.Goubault-Larrecq
- Re: Using Coq to prove properties in a restricted world, Asger Alstrup Nielsen
