- From: Laurent Thery <Laurent.Thery AT sophia.inria.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: Re: recursion in 2 args
- Date: Thu, 13 Jul 2000 15:01:18 +0200
Hi Dimitri,
a slightly more general solution than David's one is to
split your function in two:
one that is recursive on the first argurment
and one that is recursive on the second argument.
like this Coq will accept the recursion.
Following David's example, here is a possible code
aux1 is the function that is recursive on the first argument
aux2 is the function that is recursive on the second one.
Require Import PolyList.
Section a.
Variable A:Set.
Variable test:A -> A ->bool.
Definition merge :=
Fix aux1 {
aux1/1: (list A) -> (list A) ->(list A) :=
[l1, l2:(list A)]
Cases l1 l2 of
(cons a t1) (cons b t2) =>
Cases (test a b) of
true => (cons a (aux1t1 (cons b t2)))
| false =>
(Fix aux2 {aux2/1: (list A) -> (list A) :=
[l3:(list A)]
Cases l3 of
(cons c t3) =>
Cases (test a c) of
true => (cons a (aux1 t1 (cons c l3)))
| false =>(cons c (aux2 t3))
end
| nil => (cons a t1)
end
(cons b t2))
end
| nil _ => l2
| _ nil => l1
end
End a.
Mutual Inductive AB: Set :=
a: AB
| b: AB .
Definition test :=
[x, y:AB]
Cases x y of
a _ => true
| _ _ => false
end.
Eval Compute in (merge ? test (cons b (cons a (nil ?))) (cons a (nil ?))).
--Laurent
- recursion in 2 args, Dimitri Hendriks
- Re: recursion in 2 args,
David Delahaye
- Re: recursion in 2 args, Frederic Blanqui
- <Possible follow-ups>
- Re: recursion in 2 args, Laurent Thery
David Delahaye
