coq-club - "Warning: Ignoring recursive call" and Recursive Functions
chronological Thread
  • To: coq-club <coq-club AT pauillac.inria.fr>
  • Cc: Ken McMillan <mcmillan AT cadence.com>
  • Subject: "Warning: Ignoring recursive call" and Recursive Functions
  • Date: Wed, 06 Sep 2000 11:15:13 -0700
  • Organization: INRIA & Cadence Berkeley Laboratories
Hello Coq team and users,
        here follows 2 or three questions close related.
I want to formalize a set of formulas; formulas are built from
a set of operators (Oper), where each operator has an arity (>= 0).
At this point I don't want to fix a syntax, nevertheless I
want to reason about this set of objects.
So, my first attempt was to say:
Variable Oper :Set.
Variable Denotation:Set.
Variable Arity : Oper -> nat.
Inductive fla :   Set :=
 fla_intro : (f:Oper)(l:(list fla))fla .
First question: What means Coq's message:
given by this inductive definition ?
This formalization seems to work well, even if I
theoretically I want to ensure that (length l)=(Arity o).
(Note that non positiveness of:
        fla_intro : (f:Oper)(l:(list fla)) (length l)=(Arity f)->fla .
even if I can't see any "unsoundness" introduced by this definition)
I can  define the denotation of a formula
given a function  OpInterpretation, in Coq:
Variable  OpInterpretation : Oper -> (list Denotation) -> Denotation.
Fixpoint FlaDenot_1 [ fx : fla] : Denotation :=
      Cases fx of
        (fla_intro f l)=> (OpInterpretation f (map FlaDenot_1 l))
      end.
I was very surprise that Coq accepts this definition...
it seems to open the door for non-terminating functions !?
(cf. message from Maria Joao Frade on Jul/03/00 ?)
Note that the inductive scheme for the type fla
synthesized by Coq is not powerful enough...
but we can prove by hand the correct one.
Then, my second attempt was (merci Bruno):
Variable Oper :Set.
Mutual Inductive flaN :  Set :=
 fla_n : (o:Oper)(l:(listf (Arity o)))flaN
with
 listf : nat -> Set :=
   nilfla  : (listf O)
|  consfla : (n:nat)flaN -> (listf n) -> (listf (S n)).
Scheme fla_ind2     := Induction for flaN  Sort Prop
  with listf_ind2   := Induction for listf Sort Prop.
Excellent, I have the arity test, and the induction scheme!
BUT, now I want to define the denotation of a formula
Parameter Denotation : Set.
Fixpoint mapN [B: Set; fun: flaN ->B ; n:nat; l:(listf n)] : (list B) :=
 Cases l of
    nilfla           => (nil B)
  | (consfla m fh ft)=> (cons (fun fh) (mapN B fun m ft))
end.
Fixpoint FlaDenotation [ fl : flaN] : Denotation :=
      Cases fl of
        (fla_n o lf)=> (OpInterpretation o (mapN Denotation FlaDenotation
(Arity o) lf))
      end.
The last definition rises the error:
Error during interpretation of command:
       Cases fl of      (fla_n o lf)=> (OpInterpretation o (mapN Denotation
FlaDenotation (Arity o) lf))       end.
Error: Not enough arguments for the recursive call
 The recursive definition FlaDenotation :=
 [fl:flaN]
  Cases fl of
    (fla_n o lf) =>
     (OpInterpretation o (mapN Denotation FlaDenotation (Arity o) lf))
  end is not well-formed
Why this time Coq aware of the unsoundness of the definition and not in
the
former case?
Thank you all in advance for you help and/or advice,
        Pablo
PS: Follows the full script (Question.v) and an
    instantiation to play with (Question_Example.v).Require Export PolyList.
Section Formulas.
Variable Oper :Set.
      Cases fx of
      end.
End Formulas.
Section FormulasNAire.
Variable Oper :Set.
with
   nilfla  : (listf O)
 Cases l of
    nilfla           => (nil B)
end.
      Cases fl of
(Arity o) lf))
      end.
(* Error during interpretation of command:
 [fl:flaN]
  Cases fl of
    (fla_n o lf) =>
End FormulasNAire.
Require Question.
Section Example. (* petit langage booleen *)
Inductive Oper : Set :=
 TT : Oper
|FF : Oper
|nnot : Oper
|aand : Oper.
Definition Arity [o:Oper] :nat :=
 Cases o of
         TT => O
        |FF => O
        |nnot => (S O)
        |aand => (S (S O))
        end.
(* let's give a tri-valued denotation *)
Inductive boolF : Set :=
 vrai : boolF | faux : boolF | bottom : boolF.
Definition OperInterp [o:Oper ; l:(list boolF) ] : boolF :=
 Cases o of
         TT => vrai
        |FF => faux
        |nnot => Cases l of
                   nil => bottom
                  |(cons v tl) => Cases v of
                                     vrai => faux
                                   | faux => vrai
                                   | bottom => bottom
                                  end
                 end
        |aand => Cases l of
                   nil => bottom
                                     vrai =>  Cases tl of
                                                 nil => bottom
                                                |(cons v tll) => Cases v of
        vrai =>
vrai
        | faux =>
faux
        | bottom =>
bottom
        end
                                              end
                                   | faux => faux
                                   | bottom => bottom
                                  end
                end
end.
(* Examples of formulas  with arity check *)
Definition phiTT :=(fla_n Oper Arity TT (nilfla ? ?)).
Definition phi1 := (fla_n Oper Arity nnot (consfla ? ? O phiTT
                                               (nilfla ? ?))).
(*  Examples of formulas without arity check *)
Definition phiT :=(fla_intro Oper TT (nil (fla Oper))).
Definition phi2 := (fla_intro Oper nnot (cons phiT (nil (fla Oper)))).
Definition phi3 := (fla_intro Oper aand (cons phi2 (cons phiT (nil (fla
Oper))))).
Definition SemBoolF[f:(fla Oper)] := (FlaDenot_1 Oper boolF OperInterp f).
Eval Compute in (SemBoolF phi2).
Eval Compute in (SemBoolF phi3).
Eval Compute in (SemBoolF (fla_intro Oper nnot (nil (fla Oper)))).
