- From: Antonia Balaa <Antonia.Balaa AT sophia.inria.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: Types in Coq
- Date: Mon, 20 Nov 2000 16:38:37 +0100
Dear all,
I'm trying to type the expressions: titi and toto (see below),
and I would like to know why these two terms do not have the same type.
The last Check command raises an error. Could you explain me why?
Best Regards.
Antonia
Require Arith.
Require Compare_dec.
Variable x : nat.
Variable toto : O
=(<[_:{x=O}+{(lt O x)}]nat>Cases (zerop x) of
(left _) => O
| (right _) => O
end).
Variable titi : O = (Cases (zerop x) of
(left _) => O
| (right _) => O
end).
Check (titi:: O
(left _) => O
| (right _) => O
end)).
Antonia
- Types in Coq, Antonia Balaa
