- To: Bruno Barras <Bruno.Barras AT inria.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: indexing of Type; question on Coq V7.
- Date: Fri, 16 Feb 2001 14:02:17 +0000
Bruno Barras writes:
> > Definition I [T:Type; t:T] : T := t.
> > Check (I ((T:Type)T->T) I). (* self application of I fails *)
> > Error: Universe Inconsistency
> > Definition J [T:Type; t:T] : T := t.
> > Check (I ((T:Type)T->T) J). (* application of I to J succeeds *)
> > (I (T:Type)T->T J)
> > : (T:Type)T->T
> As far as I understand it, it is correct since we do not have
> universe polymorphism, so you have to write two instances of the
> identity.
Agreed, this is not a bug in Coq V6.3.1; it is the intended behavior,
chosen for reasons of efficiency and simplicity, as Bruno points out.
But I wouldn't want to call this "correct", as this behavior is not
"referentially transparent". There are pairs of terms that are
definitionally equal, e.g (I ((T:Type)T->T) I) and
(I ((T:Type)T->T) ([T:Type; t:T]t)), but do not typecheck the same in
Coq.
> Regarding the V7beta problem, this is because Check of Coq V7beta does
> typecheck the term without checking the generated universe constraints
> are compatible with the current environment. I consider this is a bug
> and the behaviour of V6.3.1 should be restored.
> Meanwhile, you'd better use Definition rather than Check:
> Parameter K: (T:Type)T->T.
> Definition y := (K ((T:Type)T->T) K).
> Error: Universe Inconsistency.
Interesting. So there is just a bug in "Check" in V7beta, but real
type-checking (as in checking a Definition) is correct. This again
raises the question whether V7beta intends to be referentially
transparent. That would be a good thing.
Best,
Randy
- Re: indexing of Type; question on Coq V7., Randy Pollack
Bruno Barras
Bruno Barras
