- To: coq-club AT pauillac.inria.fr
- Subject: Re: indexing of Type
- Date: Sun, 04 Mar 2001 15:33:09 -0100
Regarding Judicael Courant's message---
would it be possible to support A. Miquel' suggestion?
This solution (if it exists) would seem to reply fairly well to
(2) and (3) and if the user is well-informed, to (1) too.
One would have to
respond to what Miquel called ``all the problems ''
(he said ``this doesnt fix all the problems ...'')?
I don't know what these all are but I did find one when I tried
to implement his suggestion: you couldn't type
Record foo : Type3 := {
etc
for example, because Type3 isn't a sortdef.
Would it be possible to make the system accept T as a sortdef whenever
T := Type is declared?
This seems to create a limited possibility for ``subtypes'' since
in effect Type1 becomes a subtype of Type2 and so on.
Do these subtypes (or subsorts) cause some problem?
When I tried implementing Miquel's suggestion something went wrong,
cf the big file that I sent to
coq@...
a while ago;
but I don't know what it was. It may just have been due to our old
version of coq or maybe a stupid mistake on my part.
---Carlos
- Re: indexing of Type, Carlos.SIMPSON
