- To: coq-club AT pauillac.inria.fr
- Subject: Implementation of finite sets...?
- Date: Fri, 06 Apr 2001 16:53:40 +0200
Good afternoon all,
Has anyone implemented a workable encoding of finite (sub)sets in Coq? I need them to state definitions like "a vector v is a linear combination of elements of a set S if there exist a finite number of elements y_1...y_n and scalars a_1...a_n such that x=a_1 y_1+...+a_n y_n.", or "the sumvector of a finite set of vectors is v_1+v_2+...", or " a vectorspace is finite if the set of basis elements is finite".
I tried making subsets of the natural numbers (building upon an implementation of an algebraic hierarchy containing subsets by Loic Pottier) but it turned out not to work easily that way: the access to these subsets gets too involved, to the extent that I lost overview. This is not, in my opinion, a good way to go. I adhere the philosophy that a proof assistant should be exactly that: an +assistant+; and therefore it should make mathematical life easier instead of complicated.
Since I want to have my enCoqed maths resemble textbook maths as closely as possible, I want to be able (in a relatively easy way) to e.g. access every single element, or given a binary operation +, apply it to the whole bunch of them one after each other (ie. (((a_1+a_2)+a_3)+...+a_n).)
So, if any of you has, or knows about, a suitable implementation: please SHOOT...!
Many thanks in advance,
Jasper
In a world without walls and fences, who needs Windows and Gates?
- Implementation of finite sets...?, Jasper J Stein
- Re: Implementation of finite sets...?, Francois-Rene Rideau
Venanzio Capretta
- Re: Implementation of finite sets...?, Jean Goubault-Larrecq
