- To: coq-club AT pauillac.inria.fr
- Subject: Who uses this theorem?
- Date: Fri, 29 Jun 2001 16:06:01 +0200 (CEST)
As a first, primitive experiment on the use of
metadata, the HELM on line interface to the coq library
http://www.cs.unibo.it/helm/library.html
currently support the computation of all objects
containg references to a given object.
These occurrences are classifed in several groups,
according to the position of the occurrence:
- head position inside the conclusion of a statement
- head position inside an hypothesis of a statement
- other occurrences inside the conclusion
- other occurrences inside an hypothesis
- inside the body
Searching is done on the WHOLE library (the standard
one, PLUS all the main contribs).
e.g. you may discover that
cic:/Coq/Init/Peano/mult.con
occurs in head position inside the conclusion of 96
statements, such as
cic:/Algebra/Basics/le_mult_left.con
cic:/Algebra/Basics/lt_mult_right.con
cic:/Algebra/CPoly_Degree/Degree_props/Degree_le_nexp.con
and so on.
All the previous uri are obviously hyperlinks to
the corresponding definition (if the list of objects
is reasonably small, the corresponding statements
are authomatically expanded; otherwise you have
to follow the link).
In order to view these metadata you must first
reach the object you are interested in (i.e.
mult, in the above case), and then follow
the "View its metadata" link in the top frame.
Hope you will have fun (it is quite amusing).
It could be also usefull in view of a possible
restructuration of the "standard" library (and
of course in the development on new contribs).
If you have suggestion and/or comments, please
do not hesitate to contact us.
-- andrea asperti
& the HELM group
- Who uses this theorem?, Andrea Asperti
