coq-club - Re: Evaluable constant
chronological Thread
  • To: Michel Levy <Michel.Levy AT imag.fr>
  • Cc: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
  • Subject: Re: Evaluable constant
  • Date: Mon, 8 Oct 2001 21:11:18 +0200 (MET DST)
        Hi,
On Mon, 8 Oct 2001, Michel Levy wrote:
> Could you explain me what is an evaluable constant, more exactly, why I
> can "Unfold h" directly defined by
> Definition h :=  [H:bool]H  : bool->bool
> and why it's impossible when I defined f with a proof.
> I give a short sequence leading to this situation :
        Terms built in proof mode are "opaque" (i.e. non unfoldable)
whereas terms defined directly are "tranparent" (i.e. unfoldable).
        You can make a term t transparent by the "Transparent t." command.
The converse is done by "Opaque t.".
        For instance :
> Coq < Definition f : bool -> bool.
> 1 subgoal
>    bool->bool
> f < Intro H; Assumption.
> Subtree proved!
> f < Save.
> f is defined
> Coq < Print f.
> f = [H:bool]H
>      : bool->bool
Coq < Transparent f.
Coq < Goal (b:bool)((f b) = b).
1 subgoal
   (b:bool)(f b)=b
Unnamed_thm < Reflexivity.
Subtree proved!
        Xavier RIVAL
