- From: Christine Paulin <Christine.Paulin AT lri.fr>
- To: Nadeem Abdul Hamid <nadeem AT acm.org>
- Cc: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Injection
- Date: Thu, 3 Jan 2002 12:49:26 +0100
Hello,
No, this property cannot be proved.
Your inductive definition of jdef corresponds to a "sigma type" : an
element in jdef is a (dependent) pair built from a type k:set and an
element x of type k.
It is impredicative, because it contains all the objects of type Set
and is itself in Set.
We call these types "large inductive definition". In order to avoid an
inconsistency, it is forbiden to do a large elimination on an object
in that type :
when j has type jdef, I can write
Cases j of (jconst k x) => t end
only when t has type T with T of type Set or Prop but not Type
In particular, it is not possible to write the first projection
fst(j) = Cases j of (jconst k x) => k end
because t = k hat type T = Set which has type Type
The second projection, snd(j) = Cases j of (jconst k x) => x
cannot be written either because it is not possible to give it a type
the expected type should be fst(j)
The injection tactic works by building the apropriate projection and then
applying the theorem j=j' => proj(j)=proj(j')
when j and j' starts with constructors it is equivalent to
(c x)=(c x')=>x=x'
Because the injection cannot be built in the case of jdef, the
Injection tactic does not work.
I am almost sure that it cannot be proved :
The more general form
(k:Set)(x,y:k)(jconst k x)=(jconst k y)->x=y
implies what there is a unique proof of x=x, namely refl(x)
(x,y)(h:(x=y))(jconst (x=y) h)=(jconst (x=x) (refl x))
is proven by dependent elimination on the proof h:x=y
then one concludes
(h:(x=x))(jconst (x=x) h)=(jconst (x=x) (refl x))
and your property implies h=(refl x) which is known not to be provable
in the Calculus of Inductive Constructions
I would be surprised that your property can be proved just using the
extra axiom of unicity of proofs of equality (that can be added safely
to the systsm).
Actually, I cannot say wether the injection property you want
to prove can be assumed without getting an inconsistent system !
One way to get back the projections and injection properties, would be
to build jdef at the predicative level
Inductive jdef : Type := jconst : (k:Set)k -> jdef.
It depends of what you want to do with this definition
The explanation in this mail relies on some technical points about
impredicative type theories and may seem obscure if you are not
familiar with this matter.
Please do not hesitate to ask more questions and/or precise your
interest in this subject.
Christine Paulin
Nadeem Abdul Hamid writes:
> Is is possible to prove the following lemma for this
> inductive definition?
> Inductive jdef : Set
> Lemma eq_jdef : (x,y:nat)
> (jconst ? x)=(jconst ? y)
> -> x=y.
> Normally, the Injection tactic could be used, but apparently
> jdef is impredicative so it doesn't work.
> --- nadeem
Christine Paulin-Mohring mailto :
LRI, UMR 8623 CNRS, Bat 490, Université Paris Sud, 91405 ORSAY Cedex
LRI tel : (+33) (0)1 69 15 66 35 fax : (+33) (0)1 69 15 65 86
INRIA tel : (+33) (0)1 39 63 54 60 fax : (+33) (0)1 39 63 56 84
- [Coq-Club] Injection, Nadeem Abdul Hamid
- Re: [Coq-Club] Injection, Christine Paulin
