- From: Olivier Desmettre <desmettr AT pauillac.inria.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Coq CVS Archive
- Date: Mon, 14 Jan 2002 12:01:25 +0100 (MET)
The Coq development team is pleased to inform you that a new server has
been launched to provide read-only access to the Coq source tree using
anonymous CVS. This server is accessible at :
http://coqcvs.inria.fr
You can browse the file hierarchy with your Web browser and get the
different revisions. You may furthermore request differences between two
revisions of a file.
You can also download source using anonymous CVS. The two main parts of our
CVS repository are "V7" (source of the Coq proof assistant, version 7) and
"contrib" (user's contributions). To access the Coq source tree using CVS,
you need to do the following :
- Set the CVSROOT environment variable to
":pserver:anoncvs AT coqcvs.inria.fr:/coq".
- For your fisrt connection, log in using 'cvs login' and the empty
password.
- Use 'cvs checkout dirname' to create a local copy of the sources in the
current directory. Useful values of dirname are "V7" and "contrib". You can
also browse the source tree to determine the name of the subtree in which you
are interested.
- Use 'cvs update' to bring your local copy of the sources up-to-date with
respect to our repository.
For general questions on Coq CVS Archive, please contact
coqcvsmaster AT pauillac.inria.fr
(make sure you understand CVS operation well before writing us).
- [Coq-Club] Coq CVS Archive, Olivier Desmettre
