- From: Jean-Christophe Filliatre <Jean-Christophe.Filliatre AT lri.fr>
- To: rabudo AT mixmail.com
- Cc: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>, "brais AT lycos.com" <brais AT lycos.com>
- Subject: Re: [Coq-Club] A new member
- Date: Thu, 17 Jan 2002 14:15:04 +0100 (MET)
> My name is Joao
> I'm a new member of the Coq Club.
> I would like to know how to define new operations using the
> recursive scheme _rec
> I. e. If I have the next definition:
> Coq < Inductive list [X:Set]:Set :=
> Coq < Nil : (list X)
> Coq < | Cons: X -> (list X) -> (list X).
> list_ind is defined
> list_rec is defined
> list_rect is defined
> list is defined
> How I could define a function that concatenate two lists using
> list_rec?
Such lists already exist in the Coq standard library, in
Lists/PolyList.v. In particular, concatenation is defined, like this:
Fixpoint app [l:list] : list -> list
:= [m:list]Cases l of
nil => m
| (cons a l1) => (cons a (app l1 m))
end.
Hope this helps,
Jean-Christophe Filliatre (http://www.lri.fr/~filliatr)
- [Coq-Club] A new member, X.X.X.
- Re: [Coq-Club] A new member, Jean-Christophe Filliatre
- Re: [Coq-Club] A new member, Christine Paulin
