- From: Judica�l Courant <Judicael.Courant AT lri.fr>
- To: Ian Zimmerman <itz AT speakeasy.org>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] 7.2 install glitch
- Date: 18 Jan 2002 15:15:47 +0100
Dear Ian,
We apologize for the bad experienced you had trying to install Coq.
We are still investigating the problem with coq-bugs (it used to work).
As for the configure script, -e is indeed a non-standard feature of echo
in bash. I have just corrected the problem. In order to make your
installation work, you can either run a "bash configure" or apply
the enclosed configure file (I ran it on my Debian woody with ash and
the build went right). Let us know if you have any other problem.
Sincerly yours,
Judicaël Courant.
Judicael.Courant AT lri.fr,
http://www.lri.fr/~jcourant/
(+33) (0)1 69 15 64 85
"Heureux ceux qui savent rire d'eux-mêmes :
ils n'ont pas fini de s'amuser !"
#!/bin/sh ################################## # # Configuration script for Coq # ################################## VERSION=7.2 VERSIONSI=1.0 DATE="January 2002" # a local which command for sh which () { IFS=":" # set words separator in PATH to be ':' (it allows spaces in dirnames) for i in $PATH; do if test -z "$i"; then $i=.; fi if [ -f "$i/$1" ] ; then IFS=" " echo $i/$1 break fi done } bytecamlc=ocamlc nativecamlc=ocamlopt camlp4o=camlp4o coq_debug_flag= coq_profile_flag= best_compiler=opt local=false bindir_spec=no libdir_spec=no mandir_spec=no emacslib_spec=no emacs_spec=no arch_spec=no COQTOP=`pwd` # Parse command-line arguments while : ; do case "$1" in "") break;; -prefix|--prefix) bindir_spec=yes bindir=$2/bin libdir_spec=yes libdir=$2/lib/coq mandir_spec=yes mandir=$2/man shift;; -local|--local) local=true bindir_spec=yes bindir=$COQTOP/bin libdir_spec=yes libdir=$COQTOP mandir_spec=yes mandir=$COQTOP/man emacslib_spec=yes emacslib=$COQTOP/tools/emacs;; -src|--src) COQTOP=$2 shift;; -bindir|--bindir) bindir_spec=yes bindir=$2 shift;; -libdir|--libdir) libdir_spec=yes libdir=$2 shift;; -mandir|--mandir) mandir_spec=yes mandir=$2 shift;; -emacslib|--emacslib) emacslib_spec=yes emacslib=$2 shift;; -emacs |--emacs) emacs_spec=yes emacs=$2 shift;; -arch|--arch) arch_spec=yes arch=$2 shift;; -opt|--opt) bytecamlc=ocamlc.opt camlp4o=camlp4o # can't add .opt since dyn load'll be required nativecamlc=ocamlopt.opt;; -byte-only|-byteonly|--byteonly|--byte-only) best_compiler=byte;; -debug|--debug) coq_debug_flag=-g;; -profile|--profile) coq_profile_flag=-p;; *) echo "Unknown option \"$1\"." 1>&2; exit 2;; esac shift done # compile date DATEPGM=`which date` case $DATEPGM in "") echo "I can't find the program \"date\" in your path." echo "Please give me the current date" read COMPILEDATE;; *) COMPILEDATE=`date +"%h %d %Y %H:%M:%S"`;; esac # Architecture case $arch_spec in no) if test -f /bin/arch ; then ARCH=`/bin/arch` elif test -f /usr/bin/arch ; then ARCH=`/usr/bin/arch` elif test -f /usr/ucb/arch ; then ARCH=`/usr/ucb/arch` elif /bin/uname -s | grep -q -i CYGWIN ; then ARCH=win32 # cygwin returns a name of the form \\cygdrive\\c\\... # that coqc does not understand; need to transform it COQTOP=`echo $COQTOP | sed -e "s#.*cygdrive.\(.\)#\1:#"` else echo "I can not automatically find the name of your architecture" echo -n\ "Give me a name, please [win32 for Win95, Win98 or WinNT]: " read ARCH fi;; yes) ARCH=$arch esac # bindir, libdir, mandir, etc. case $ARCH in win32) bindir_def=\\coq\\bin libdir_def=\\coq\\lib mandir_def=\\coq\\man emacslib_def=\\coq\\emacs;; *) bindir_def=/usr/local/bin libdir_def=/usr/local/lib/coq mandir_def=/usr/local/man emacslib_def=/usr/share/emacs/site-lisp;; esac emacs_def=emacs case $bindir_spec in no) echo "Where should I install the Coq binaries [$bindir_def] ?" read BINDIR case $BINDIR in "") BINDIR=$bindir_def;; *) true;; esac;; yes) BINDIR=$bindir;; esac case $libdir_spec in no) echo "Where should I install the Coq library [$libdir_def] ?" read LIBDIR case $LIBDIR in "") LIBDIR=$libdir_def;; *) true;; esac;; yes) LIBDIR=$libdir;; esac case $mandir_spec in no) echo "Where should I install the Coq man pages [$mandir_def] ?" read MANDIR case $MANDIR in "") MANDIR=$mandir_def;; *) true;; esac;; yes) MANDIR=$mandir;; esac case $emacslib_spec in no) echo "Where should I install the Coq Emacs mode [$emacslib_def] ?" read EMACSLIB case $EMACSLIB in "") EMACSLIB=$emacslib_def;; *) true;; esac;; yes) EMACSLIB=$emacslib;; esac # case $emacs_spec in # no) echo "Which Emacs command should I use to compile coq.el [$emacs_def] ?" # read EMACS # case $EMACS in # "") EMACS=$emacs_def;; # *) true;; # esac;; # yes) EMACS=$emacs;; # esac # OS dependent libraries case $ARCH in sun4*) OS=`uname -r` case $OS in 5*) OS="Sun Solaris $OS" OSDEPLIBS="-cclib -lunix -cclib -lnsl -cclib -lsocket";; *) OS="Sun OS $OS" OSDEPLIBS="-cclib -lunix" esac;; alpha) OSDEPLIBS="-cclib -lunix";; win32) OS="Win32" OSDEPLIBS="-cclib -lunix";; *) OSDEPLIBS="-cclib -lunix" esac # OS dependent camlp4 options for native compilation # executable extension case $ARCH in win32) EXE=".exe";; *) EXE="" esac # Objective Caml programs CAMLC=`which $bytecamlc` case "$CAMLC" in "") echo "$bytecamlc is not present in your path !" echo "Give me manually the path to the ocamlc executable [/usr/local/bin by default]: " read CAMLC case "$CAMLC" in "") CAMLC=/usr/local/bin/ocamlc;; */ocamlc|*/ocamlc.opt) true;; */) CAMLC="${CAMLC}"ocamlc;; *) CAMLC="${CAMLC}"/ocamlc;; esac bytecamlc="$CAMLC" nativecamlc=`dirname "$CAMLC"`/$nativecamlc;; esac if test ! -f "$CAMLC" ; then echo "I can not find the executable '$CAMLC'! (Have you installed it?)" echo "Configuration script failed!" exit 1 fi CAMLBIN=`dirname "$CAMLC"` CAMLVERSION=`"$CAMLC" -v | sed -n -e 's|.*version* *\(.*\)$|\1|p' ` case $CAMLVERSION in 1.*|2.*|3.00) echo "Your version of Objective-Caml is $CAMLVERSION." echo "You need Objective-Caml 3.01 or later !" echo "Configuration script failed!" exit 1;; ?*) echo "You have Objective-Caml $CAMLVERSION. Good!";; *) echo "I found the Objective-Caml compiler but cannot find its version number!" echo "Is it installed properly ?" echo "Configuration script failed!" exit 1;; esac # do we have a native compiler: test of ocamlopt and its version if [ "$best_compiler" = "opt" ] ; then CAMLOPT=`which $nativecamlc` case "$CAMLOPT" in "") best_compiler=byte echo "You have only bytecode compilation.";; *) CAMLOPTVERSION=`"$CAMLOPT" -v | sed -n -e 's|.*version* *\(.*\)$|\1|p' ` if [ "$CAMLOPTVERSION" != "$CAMLVERSION" ] ; then \ echo "native and bytecode compilers do not have the same version!"; fi echo "You have native-code compilation. Good!" esac fi # For coqmktop CAMLLIB=`"$CAMLC" -v | sed -n -e 's|.*directory:* *\(.*\)$|\1|p' ` # Tell on windows if ocaml understands cygwin or windows path formats "$CAMLC" -o config/giveostype config/giveostype.ml CAMLOSTYPE=`config/giveostype` rm config/giveostype # Camlp4 CAMLP4=`which $camlp4o` case "$CAMLP4" in "") echo "camlp4 is not present in your path!" echo "Give me manually the path to the camlp4 executable [/usr/local/bin by default]: " read CAMLP4 case "$CAMLP4" in "") CAMLP4=/usr/local/bin/camlp4o;; */camlp4) CAMLP4=${CAMLP4}o;; */camlp4o) true;; */) CAMLP4="${CAMLP4}"camlp4o;; *) CAMLP4="${CAMLP4}"/camlp4o;; esac camlp4o="$CAMLP4";; esac if test ! -f "$CAMLP4" ; then echo "I can not find the executable '$CAMLP4'! (Have you installed it?)" echo "Configuration script failed!" exit 1 fi CAMLP4BIN=`dirname "$CAMLP4"` CAMLP4VERSION=`"$CAMLP4" -v 2>&1 | sed -n -e 's|.*version *\(.*\)$|\1|p'` case $CAMLP4VERSION in 0.*|1.*|2.00|3.00*) echo "Your version of Camlp4 is $CAMLP4VERSION." echo "You need Camlp4 3.01 or later !" echo "Configuration script failed!" exit 1;; ?*) echo "You have Camlp4 $CAMLP4VERSION. Good!";; *) echo "I found Camlp4 but cannot find its version number!" echo "Is it installed properly ?" echo "Configuration script failed!" exit 1;; esac case $CAMLP4VERSION,$CAMLOSTYPE in 3.04,*) CAMLP4LIB=+camlp4;; *,Win32) CAMLP4LIB=`"$CAMLP4" -where |sed -e 's|\\\|/|g'`;; *,*) CAMLP4LIB=`"$CAMLP4" -where`;; esac case $ARCH in win32) STRIPCOMMAND="true";; *) if [ "$coq_profile_flag" = "-p" ] ; then STRIPCOMMAND="true" else STRIPCOMMAND="strip" fi esac # Summary of the configuration echo "" echo " Coq top directory : $COQTOP" echo " Architecture : $ARCH" if test ! -z "$OS" ; then echo " Operating system : $OS" fi echo " OS dependent libraries : $OSDEPLIBS" echo " Objective-Caml version : $CAMLVERSION" echo " Objective-Caml binaries in : $CAMLBIN" echo " Objective-Caml library in : $CAMLLIB" echo " Camlp4 version : $CAMLP4VERSION" echo " Camlp4 binaries in : $CAMLP4BIN" echo " Camlp4 library in : $CAMLP4LIB" echo "" echo " Paths for true installation:" echo " binaries will be copied in $BINDIR" echo " library will be copied in $LIBDIR" echo " man pages will be copied in $MANDIR" echo " emacs mode will be copied in $EMACSLIB" echo "" # Building the $COQTOP/config/Makefile file rm -f $COQTOP/config/Makefile case $ARCH in win32) BINDIR=`echo $BINDIR |sed -e 's|\\\|/|g'` LIBDIR=`echo $LIBDIR |sed -e 's|\\\|/|g'` MANDIR=`echo $MANDIR |sed -e 's|\\\|/|g'`;; esac #case $CAMLOSTYPE in # Win32) # CAMLP4BIN=`echo $CAMLP4BIN |sed -e 's|\\\|/|g'` # CAMLP4LIB=`echo "$CAMLP4LIB" | sed -e 's|\\\|\\\\\\\\|g'` # CAMLP4BIN=`echo $CAMLC |sed -e 's|\\\|/|g'` # CAMLP4BIN=`echo $CAMLLIB |sed -e 's|\\\|/|g'` # ;; #esac sed -e "s|LOCALINSTALLATION|$local|" \ -e "s|COQTOPDIRECTORY|$COQTOP|" \ -e "s|COQVERSION|$VERSION|" \ -e "s|BINDIRDIRECTORY|$BINDIR|" \ -e "s|COQLIBDIRECTORY|$LIBDIR|" \ -e "s|MANDIRDIRECTORY|$MANDIR|" \ -e "s|EMACSLIBDIRECTORY|$EMACSLIB|" \ -e "s|EMACSCOMMAND|$EMACS|" \ -e "s|ARCHITECTURE|$ARCH|" \ -e "s|OSDEPENDENTLIBS|$OSDEPLIBS|" \ -e "s|OSDEPENDENTP4OPTFLAGS|$OSDEPP4OPTFLAGS|" \ -e "s|CAMLLIBDIRECTORY|$CAMLLIB|" \ -e "s|CAMLP4BINDIRECTORY|$CAMLP4BIN|" \ -e "s|CAMLP4LIBDIRECTORY|$CAMLP4LIB|" \ -e "s|CAMLP4TOOL|$camlp4o|" \ -e "s|COQDEBUGFLAG|$coq_debug_flag|" \ -e "s|COQPROFILEFLAG|$coq_profile_flag|" \ -e "s|BESTCOMPILER|$best_compiler|" \ -e "s|EXECUTEEXTENSION|$EXE|" \ -e "s|BYTECAMLC|$bytecamlc|" \ -e "s|NATIVECAMLC|$nativecamlc|" \ -e "s|STRIPCOMMAND|$STRIPCOMMAND|" \ $COQTOP/config/Makefile.template > $COQTOP/config/Makefile chmod a-w $COQTOP/config/Makefile # Building the $COQTOP/dev/ocamldebug-v7 file if test "$coq_debug_flag" = "-g" ; then rm -f $COQTOP/dev/ocamldebug-v7 sed -e "s|COQTOPDIRECTORY|$COQTOP|" \ -e "s|COQLIBDIRECTORY|$LIBDIR|" \ -e "s|CAMLBINDIRECTORY|$CAMLBIN|" \ -e "s|CAMLP4LIBDIRECTORY|$CAMLP4LIB|" \ $COQTOP/dev/ocamldebug-v7.template > $COQTOP/dev/ocamldebug-v7 chmod a-w,a+x $COQTOP/dev/ocamldebug-v7 fi # Building the $COQTOP/config/coq_config.ml file mlconfig_file=$COQTOP/config/coq_config.ml rm -f $mlconfig_file cat << END_OF_COQ_CONFIG > $mlconfig_file (* DO NOT EDIT THIS FILE: automatically generated by ../configure *) let local = $local let bindir = "$BINDIR" let coqlib = "$LIBDIR" let coqtop = "$COQTOP" let camllib = "$CAMLLIB" let camlp4lib = "$CAMLP4LIB" let best = "$best_compiler" let arch = "$ARCH" let osdeplibs = "$OSDEPLIBS" let version = "$VERSION" let versionsi = "$VERSIONSI" let date = "$DATE" let compile_date = "$COMPILEDATE" let exec_extension = "$EXE" END_OF_COQ_CONFIG # to be sure printf is found on windows when spaces occur in PATH variable PRINTF=`which printf` # Subdirectories of theories/ added in coq_config.ml subdirs () { (cd $1; find . -type d ! -name CVS ! -name . -exec $PRINTF "\"%s\";\n" {} \; >> $mlconfig_file) } echo "let theories_dirs = [" >> $mlconfig_file subdirs theories echo "]" >> $mlconfig_file echo "let contrib_dirs = [" >> $mlconfig_file subdirs contrib echo "]" >> $mlconfig_file if test "$CAMLOSTYPE" = "Win32" ; then # We change: / -> \\ and \ -> \\ (dos paths) # This is a bit tricky sed -e "s|\\\\\\\\\\\\\\\|\\\|" -e "s|/|\\\|g" -e "s|\\\|\\\\\\\|g" $mlconfig_file > $mlconfig_file.win mv $mlconfig_file.win $mlconfig_file fi chmod a-w $mlconfig_file echo "If anything in the above is wrong, please restart './configure'" echo echo "*Warning* To compile the system for a new architecture" echo " don't forget to do a 'make archclean' before './configure'." # $Id: configure,v 1.40 2002/01/10 18:36:07 herbelin Exp $
- [Coq-Club] 7.2 install glitch, Ian Zimmerman
- Re: [Coq-Club] 7.2 install glitch, Judicaël Courant
- Re: [Coq-Club] 7.2 install glitch, Ian Zimmerman
