coq-club - [Coq-Club] Lambda-calculus with deBruijn representation
chronological Thread
  • To: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] Lambda-calculus with deBruijn representation
  • Date: Sat, 19 Jan 2002 12:12:04 -0500
  • Organization: Yale University
Hello all,
I am trying to encode the lambda calculus in Coq using de Bruijn indices,
using an encoding style which keeps track of the number of free variables
in the type. So, here's the representation:
Inductive Lamexp : nat -> Set
  := var  : (i:nat) (Lamexp (S i))
  |  abs  : (i:nat) (Lamexp (S i)) -> (Lamexp i)
  |  app  : (i:nat) (Lamexp i) -> (Lamexp i) -> (Lamexp i)
  |  lift : (i:nat) (Lamexp i) -> (Lamexp (S i)).
A variable of index i must imply it is a term of (i+1) free variables. Abstractions encapsulate a term with at least one free variable. The lift is used because a term of i free variables can also be viewed as a term with (i+1) free variables (where the (i+1)'th variable is not present).
Now, I want to write a substitution function which substitutes a term for the *outermost* free variable in a given term. So the type is something like:
Definition Subst (k:nat) (Lamexp (S k)) -> (Lamexp k) -> (Lamexp k).
Of course, this should be written as a fix-point and I think the correct way it should work is something like this:
Fixpoint Subst [k:nat; L:(Lamexp (S k))] : (Lamexp k) -> (Lamexp k)
:= [T]
Cases L of (var i) -> T (* because it must be the outermost *)
         | (abs O R) -> (abs O R)
         | (abs (S i) R) -> (abs i (Subst (S i) R (lift i T)))
         | (app O a b) -> (app O a b)
         | (app (S i) a b) -> (app i (Subst i a T) (Subst i b T))
| (lift i R) -> R (* if term R contained the variable at the outermost level, it wouldn't need lifting *)
There are some problems here, since the above code doesn't work:
- Actually, the (abs O...) and (app O...) cases cannot occur because of the type of L.
- Additionally, in some cases, you need to know that i=k for the type to match the expected by of Subst.
- Now, usually, I've seen the above two situations solved by wrapping the "Cases" and having it take an additional parameter which would prove equality between i and k, and then you use "eq_ind/rec" (and "False_rec") to work it all out. Unfortunately, it seems doing this pushes the recursive calls to Subst under an abstraction and then Coq gives an "ill-founded recursion" error.
So, any ideas on this will be most appreciated. I don't know what are the exact limitations on the Fixpoint/Cases syntax and whether it allows this to be defined, or maybe I have to use directly the more primitive "Lamexp_rec" to defined Subst?
Now, if this problem above is really solvable in Coq, then I would actually like to do a little more. Let's say I also want to add tuples to the language. So they could be represented as something like:
  |  tup  : (i:nat) (list (Lamexp i)) -> (Lamexp i)
or, building in an isomorphic definition of lists:
Mutual
  |  tup  : (i:nat) (LamexpL i) -> (Lamexp i)
with
LamexpL : nat -> Set
  := nilL : (i:nat)(LamexpL i)
  | consL : (i:nat)(Lamexp i) -> (LamexpL i) -> (LamexpL i)
So, now instead of one fixpoint, there would be two mutually recursive fixpoints needed to define the substitution function above, correct?
Any suggestions/help is greatly appreciated.
--- nadeem
