coq-club - Re: [Coq-Club] equality/injection
chronological Thread
  • From: Christine Paulin <Christine.Paulin AT lri.fr>
  • To: Nadeem Abdul Hamid <nadeem AT acm.org>
  • Cc: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] equality/injection
  • Date: Mon, 4 Feb 2002 18:05:22 +0100
Yes, the only trick is to use a dependent elimination for type
DefProp which is not define automatically but can be
introduced using the Scheme macro :
Scheme DefProp_elim := Induction for DefProp Sort Prop.
Lemma eq_comb
   : (d1,d1':Def1)d1=d1'->(d2:(DefProp d1); d2':(DefProp d1'))
     (c3 d1 d2)=(c3 d1' d2').
Destruct 1.
Intro d2.
Elim d2 using DefProp_elim.
Intros d d2'.
Elim d2' using DefProp_elim; Trivial.
Save.
Nadeem Abdul Hamid writes:
 > Can the following lemma be proven in Coq?:
 > Inductive Def1 : Set
 >    := c1 : Def1.
 > Inductive DefProp : Def1 -> Prop
 >    := c2 : (d:Def1)(DefProp d).
 > Inductive Comb : Set
 >    := c3 : (d:Def1)(DefProp d) -> Comb.
 > Lemma eq_comb
 >    : (d1,d1':Def1; d2:(DefProp d1); d2':(DefProp d1'))
 >      d1=d1' ->
 >      (c3 d1 d2)=(c3 d1' d2').
 > Thanks in advance,
 > --- nadeem
  Christine Paulin-Mohring             mailto :
  LRI, UMR 8623 CNRS, Bat 490, Université Paris Sud,   91405 ORSAY Cedex
  LRI   tel : (+33) (0)1 69 15 66 35       fax : (+33) (0)1 69 15 65 86
  INRIA tel : (+33) (0)1 39 63 54 60       fax : (+33) (0)1 39 63 56 84
