- From: Christine Paulin <Christine.Paulin AT lri.fr>
- To: Pierre Casteran <casteran AT labri.u-bordeaux.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Unfolding Cofixpoints
- Date: Tue, 5 Mar 2002 09:22:09 +0100
Yes there is a systematic way to do that.
The trick is to replace the fixpoint T with the provably equal term
Cases T of c1 => c1 | ... | cn => cn end
then iota reduction applies
In your case:
Lemma LList_decompose :
(l:LList)l = (Cases l of LNil => LNil | (LCons a l) => (LCons a l) end).
Destruct l; Trivial.
Save.
Lemma repeat_unfold : (a:A)(repeat a)=(LCons a (repeat a)).
Proof.
Intro a; Apply trans_equal with 1:=(LList_decompose (repeat a)); Trivial.
Qed.
This scheme is explained in papers by E. Gimenez on co-inductive type,
see for instance the Tutorial on recursive types
Christine
Pierre Casteran writes:
> Hello,
> Hello,
> In the framework of potentially infinite lists, I proved the
> theorem (repeat a)=(LCons a (repeat a)) ; the proof uses some
> case analysis ; is there a way (reewriting, specialized tactics ...) to
> do it more simply ?
> Pierre
> Section LLists.
> Set Implicit Arguments.
> Variable A : Set.
> CoInductive Set LList :=
> LNil : LList
> |LCons : A -> LList -> LList.
> Definition decompose : LList -> (option (A*LList))
> := [l:LList]Case l of (None ?)
> [a:A;l':LList]
> (Some ? (a,l'))
> end.
> CoFixpoint repeat : A->LList :=
> [a:A](LCons a (repeat a)).
> Lemma repeat_decompose : (a:A)(decompose (repeat a))=
> (Some ? (a,(repeat a))).
> Proof.
> Intro;Simpl;Auto.
> Qed.
> Lemma decompose_eq_1 : (l : LList)(a:A)(l':LList)
> (decompose l)=(Some ? (a,l')) ->
> l=(LCons a l').
> Proof.
> Intros l a l';Case l;Simpl.
> Intro H;Discriminate H.
> Intros a0 l0 H0;Injection H0;Auto.
> Intros H1 H2;Rewrite H1;Rewrite H2;Auto.
> Qed.
> Proof.
> Intro a;Apply decompose_eq_1.
> Apply repeat_decompose.
> Qed.
> Pierre Casteran,
> LaBRI, Universite Bordeaux-I |
> 351 Cours de la Liberation |
> F-33405 TALENCE Cedex |
> France |
> tel : (+ 33) 5 56 84 69 31
> fax : (+ 33) 5 56 84 66 69
> email: Pierre . Casteran @ labri . u-bordeaux . fr (but whithout white
> space)
> www: http://dept-info.labri.u-bordeaux.fr/~casteran
Christine Paulin-Mohring mailto :
LRI, UMR 8623 CNRS, Bat 490, Université Paris Sud, 91405 ORSAY Cedex
LRI tel : (+33) (0)1 69 15 66 35 fax : (+33) (0)1 69 15 65 86
INRIA tel : (+33) (0)1 39 63 54 60 fax : (+33) (0)1 39 63 56 84
- [Coq-Club] Unfolding Cofixpoints, Pierre Casteran
- Re: [Coq-Club] Unfolding Cofixpoints, Christine Paulin
