- To: Eduardo.Gimenez AT trusted-logic.fr
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Warning
- Date: Wed, 17 Apr 2002 13:17:12 -0400
- Organization: Yale University
For example, defining pred as below, using the name "plus" as a matching variable (where "plus" is also a predeclared function), means that in the body of the successor case, you cannot use "plus" as the addition function.
Definition mypred := [n:nat] (Cases n of O => O | (S plus) => plus end).
Warning: Defined reference plus is here considered as a matching variable
--- nadeem
Eduardo Gimenez wrote:
What is the meaning of this warning and which command raises it up??
"Warning: Defined reference data is here considered as a matching variable"
To unsubscribe, mail
coq-club-request AT pauillac.inria.fr
Bug reports: http://coq.inria.fr/bin/coq-bugs
Coq-Club Archives: http://coq.inria.fr/mailing-lists/coqclub/
- [Coq-Club] Warning, Eduardo Gimenez
- Re: [Coq-Club] Warning, Hugo Herbelin
- Re: [Coq-Club] Warning, Nadeem Abdul Hamid
