- To: <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] question about Fixpoint
- Date: Thu, 8 Aug 2002 22:42:02 -0400 (EDT)
I have a question about the use of Fixpoint. In my example, I have a
tree data structure where the label at each node is a list of natural
numbers defined as:
Require Import PolyList.
Inductive Tree : Set :=
Node : (list nat) -> (list Tree) -> Tree.
The second argument represents the children of a node as a list of
trees. If the list is empty, the Node is considered a leaf.
I want to write a function that takes a list of nats and builds a tree
as follows: the input list is the label of the root; the labels of the
children are determined from the label of the parent (via a function
call); for the base case, there is a function that determines if a
particular list of nats should be the label of a leaf. For this
example, it doesn't matter how these functions work, so they are
introduced as parameters:
Parameter getSublists : (list nat) -> (list (list nat)).
Parameter check_for_base : (list nat) -> bool.
The maximum depth of the tree that is created is known in advance, and
this number is used as a decreasing measure in the recursive calls.
I tried to define this function using mutual recursion via Fixpoint as
follows:
Fixpoint buildTree [l:(list nat)][n:nat] : Tree :=
(Cases n of
O => (Node (nil nat) (nil Tree))
| (S m) => (if (check_for_base l)
then (Node l (mapBuildTree m (getSublists l)))
else (Node l (nil Tree)))
end)
with mapBuildTree [n:nat][l:(list (list nat))] : (list Tree) :=
(Cases l of
nil => (nil Tree)
| (cons x xs) => (cons (buildTree x n) (mapBuildTree n xs))
end).
but I get an error message that doesn't give much information:
Recursive call applied to an illegal term
The 1-th recursive definition buildTree :=
[l:(list nat); n:nat]
Cases n of
| (S m) =>
end is not well-formed
If I try to break the mutual recursion by assuming each node has at
most one child, then it works:
Parameter getSublist : (list nat) -> (list nat).
(Cases n of
then (Node l (cons (buildTree (getSublist l) m) (nil Tree)))
end).
Fixpoint mapBuildTree [n:nat][l:(list (list nat))] : (list Tree) :=
(Cases l of
nil => (nil Tree)
end).
Is this a limitation of Fixpoint, or am I doing something wrong?
Thanks in advance for any information.
Amy
- [Coq-Club] question about Fixpoint, Amy Felty
- Re: [Coq-Club] question about Fixpoint, Eduardo Gimenez
