coq-club - [Coq-Club] NewInduction and the previous hypotheses
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] NewInduction and the previous hypotheses
  • Date: Tue, 5 Nov 2002 19:36:19 +0100
Hi,
This is probably again a basic question, but it is driving me nuts:
NewInduction breaks the links between two instances of the same
thing, and I have no clue what to use instead or what I am doing
wrong.
Here is an example, I simplified the most I could:
(* an inhabitant of T is a set of inhabitants of T, indexed by some
   index type I *)
Inductive T:Type := T_cons: (I:Type) (I->T) -> T.
Inductive Tlte : T -> T -> Prop :=
  Tlte_cons : (xI:Type)(xf:xI->T) (y:T)
              ((xi:xI)(NTgte (xf xi) y)) -> (Tlte (T_cons xI xf) y)
with NTgte : T -> T -> Prop :=
  Tgte_cons : (xI:Type)(xf:xI->T) (y:T)
              (exT xI [xi:xI](Tlte (xf xi) y)) -> (NTgte (T_cons xI xf) y).
Think of "Tlte" to be an pre-order on T (less than or equal), and Tgte
as "not bigger than or equal".
Now, I want to prove that the relation between those two is indeed
what I intend of it, by induction. Let's focus on "(NTgte x y) -> ~(Tlte y
x)".
I thus basically need this theorem:
Theorem Step: (xI:Type)(xf:xI->T) (y:T)
              [x:=(T_cons xI xf)]
              ((xi:xI) (NTgte y (xf xi)) -> ~(Tlte (xf xi) y)) ->
              ((NTgte x y) -> ~(Tlte y x)).
I do "Intros", and I have:
1 subgoal
  xI : Type
  xf : xI->T
  y : T
  x := (T_cons xI xf) : T
  H : (xi:xI)(NTgte y (xf xi))->~(Tlte (xf xi) y)
  H0 : (NTgte x y)
   ~(Tlte y x)
Now, I do "NewInduction H0.", in order to get the proof of (NTgte x
y), which can only be an application of Tgte_cons, with arguments xI
xf y, and a p of type (exT xI [xi:xI](Tlte (xf xi) y)).
But somehow, Coq decides to introduce a *new* xI0 and a *new* xf0,
"forgetting" that those are xI and xf, because x:=(T_cons xI xf):
1 subgoal
  xI : Type
  xf : xI->T
  y : T
  xI0 : Type
  xf0 : xI0->T
  H0 : (EXT xi:xI0 | (Tlte (xf0 xi) y))
   ~(Tlte y (T_cons xI0 xf0))
You see my problem? If I had (H0:(EXT xi:xI | (Tlte (xf xi) y))), I
could do "Elim H0; Intros. Absurd (Tlte (xf0 x) y). [Apply H |
Assumption]." and just have the goal "NTgte y (xf xi)" to
prove. (Which is not possible in this Environment, but if instead of /
before the "Absurd", I do "Unfold not; Intros.", it is provable from
the new hypothesis. But it gets intricate, and the names given by Coq
are confusing, so I'll spare you the expressions.)
I can't see why Coq wants to introduce a *new* xf0 and xI0 like
that. Maybe I'm simply using the bad tactic? Tried NewDestruct too,
the results are similar. Oh, and doing Zeta-reduction (replacing x by
its definition) doesn't work either.
For your convenience, the whole Coq code in one go:
              [x:=(T_cons xI xf)]
Proof.
Intros.
NewInduction H0.
Elim H0; Intros.
2: Assumption.
Apply H. (* Should work! *)
Thank you for your insight,
Lionel
Attachment: pgpd65K3wkJyy.pgp
Description: PGP signature
