- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Is nat in Type_0?
- Date: Wed, 6 Nov 2002 12:39:25 +0100
Hi,
I'm confused about the relation between the inhabitants of Set (and
Prop) and the Type(i) hierarchy.
In the Coq _implementation_, it is the case that if x:Set or x:Prop,
than x:Type(i) for some i (I strongly think it is any i)
Inductive Foo: Type:= Cons:Type->Foo.
Parameter A:Set.
Parameter P:Prop.
Now,
Check (Cons P).
answers
(Cons P)
: Foo
and similarly "Check (Cons A)." says that (Cons A) is of type Foo.
But looking at the typing rules, page 72/73 of the Reference Manual
(section 4.2, paragraph "Typing Rules"), I don't see any justification
for it:
- Ax gives Set:Type(q), but not nat:Type(q) or True:Type(p)
- No other rule applies
So is this a documentation bug?
If I look, e.g. at the description of CIC in "Sets in Types, Types in
Sets" from Benjamin Werner, there is an explicit rule, called
Cum-Prop, that says "if A:Prop, then A:Type_i".
So, how, from the rules in the manual, does Coq infer something like
Benjamin Werner's "Cum-Prop"?
Thank you for your explanations,
Lionel
pgpDcE8FCFVFu.pgp
Description: PGP signature
- [Coq-Club] Is nat in Type_0?, Lionel Elie Mamane
- Re: [Coq-Club] Is nat in Type_0?, Lionel Elie Mamane
