- To: Hugo Herbelin <hugo.herbelin AT inria.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Problemes with extendable grammars
- Date: Wed, 04 Dec 2002 17:10:50 +0100
- Organization: LaBRI
It seems that some problems come from the "?"
For instance,
This is OK :
Grammar mytypes int_chevrons :=
chevrons [ ">>"] -> [(nil nat)].
But not this one.
Grammar mytypes2 int_chevrons2 :=
chevrons2 [ ">>"] -> [(nil ?)].
Toplevel input, characters 136-137
> Grammar mytypes2 int_chevrons2 := chevrons2 [ ">>"] -> [(nil ?)].
Syntax error: [Prim.ast] expected after [astident] (in [Prim.ast])
Pierre
Any way, is the notation for polymorphic lists is to be available,
it will be OK.
Pierre
Hugo Herbelin wrote:
Hi,
I wanted to have some notation for some kinds of lists.
What is wrong with the following definition ?
Pierre
Require PolyList.
Grammar listes inside_list : ast list :=
inside_cons [constr($a) listes:inside_list($b)] ->
[(cons $a $b)]
|inside_one [constr0($a) ">>"] ->[(cons $a (nil ?))].
The type "ast list" implies that the right hand side is parsed as an
ast list, but you give a term. Use ": constr" instead.
I seize to opportunity to question the relevance of continuing
supporting Grammar (for constr) in the next versions of Coq knowing
that a new mechanism for symbolic notations has been developed. The
new mechanism allows to define e.g. the concrete syntax for sig (both
parsing and printing) as simply as follows:
Notation "{ x : A | P }" := (sig A [x:A]P) (at level 1).
The new mechanism allows also to use the concrete syntax of operators
on Z or R (or even nat or positive) without quotes or double quotes
(one just says in advance what should be the default interpretation of
symbols in the current development).
However it does not support recursive notations and hence does not
allow to write a list in a format like << a b c >> or {a;b;c;d}, etc.
Hugo
Pierre Casteran,
LaBRI, Universite Bordeaux-I |
351 Cours de la Liberation |
F-33405 TALENCE Cedex |
France |
tel : (+ 33) 5 56 84 69 31
fax : (+ 33) 5 56 84 66 69
email: Pierre . Casteran @ labri . u-bordeaux . fr (but whithout white space)
www: http://dept-info.labri.u-bordeaux.fr/~casteran
- Re: [Coq-Club] Problemes with extendable grammars, Pierre Casteran
- Re: [Coq-Club] Problemes with extendable grammars, Hugo Herbelin
