- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Bug or feature?
- Date: Thu, 06 Feb 2003 17:03:23 +0100
Hi all,
I am trying to put Coq modules to work and there are something I find
annoying. Very often I need to forget the structure of inductive type
of some elements like in the following example:
Module Type Test_Sig.
Variable X : Type.
End Test_Sig.
Module Test <: Test_Sig.
Record X : Type := {
x : Type
End Test.
Error: Signature components for label X do not match
The only solution I found is to change the definition of Test as
follows:
Record _X : Type := {
x : Type
Definition X : Type := _X.
End Test.
Is it possible to do the same thing more directly?
Thanks,
marco
- [Coq-Club] Bug or feature?, Marco Maggesi
