- To: Giuseppe Castagna <Giuseppe.Castagna AT ens.fr>
- Cc: Claudio Sacerdoti Coen <sacerdot AT cs.unibo.it>, coq-club AT pauillac.inria.fr, Veronique Benzaken <Veronique.Benzaken AT lri.fr>, Alain Frisch <frisch AT clipper.ens.fr>, Burelle Marwan <Marwan.Burelle AT lri.fr>
- Subject: Re: [Coq-Club] Build an Coq-CDuce extraction functionnality.
- Date: Wed, 12 Feb 2003 15:14:38 +0100 (MET)
On 12 Feb 2003, Giuseppe Castagna wrote:
> On Tue, 2003-02-11 at 16:47, Claudio Sacerdoti Coen wrote:
> > Dear Serge,
> > On Tue, Feb 11, 2003 at 15:05:08 +0100, Serge Leblanc wrote:
> > > Hello, for my first contribution I wish to
> > > carry out a Coq->CDuce[1] extraction functionality.
> > what do you want to extract exactly?
> Hello Serge,
> I was asking myself exactly the same question. Do you want to extract
> XML transformations that you specify in Coq? I'm *very* curious to know
> why you chose CDuce as a target language (I'm not against it, on the
> contrary!... FYI I'm one of the persons working on the definition of
> CDuce). I see that the higher order functions of CDuce can be useful
> for that, but it seems a little bit hard to compensate the absence of
> polymorphic types (and I cannot promise you that we will come out with a
> satisfactory definition in short time).
> All the best
> ---Beppe---
This is the right question.
- If the goal is to translate complete Coq terms to other syntax,
(for documentation purpose for example) then the XML output by Claudio
is what you need.
- If the goal is to produce real programs and make fast computations, then
you should take advantage of the existing Coq extraction:
* parts that have no computational meaning (purely logical parts) are
removed automatically.
* I have already quite a experience in translating the so-complex Coq
types to poor Ocaml types. This part is not yet well documented.
Basically I remove dependancy upon terms in types, and whenever there
is no simple counterpart for a Coq type (for example "if b then nat
else bool") then I use an "unknown" or "Top" type (Obj.t in Ocaml).
And finally in the extracted terms, unsafe casts (Obj.magic:'a->'b)
are inserted wherever the Ocaml type-checker is not happy.
As I said to Serge in a previous answer to coq-club, I think this
technology is adaptable to any ML dialect, including CDuse.
Pierre Letouzey
PS: What about a meeting about this Coq->CDuse extraction ? I don't know
where Serge is geographically located, but at least the database and
demons groups of LRI are not far away. And ENS Ulm isn't at the
antipodes...
- [Coq-Club] Build an Coq-CDuce extraction functionnality., Serge Leblanc
- Re: [Coq-Club] Build an Coq-CDuce extraction functionnality.,
- Re: [Coq-Club] Build an Coq-CDuce extraction functionnality., Veronique Benzaken
Giuseppe Castagna
- Re: [Coq-Club] Build an Coq-CDuce extraction functionnality., Pierre Letouzey
Serge Leblanc
- Re: [Coq-Club] Build an Coq-CDuce extraction functionnality., Giuseppe Castagna
