coq-club - Re: [Coq-Club] dependent types
chronological Thread
  • From: Christine Paulin <Christine.Paulin AT lri.fr>
  • To: "Patricia Peratto" <pperatto AT hotmail.com>
  • Cc: <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] dependent types
  • Date: Sun, 23 Mar 2003 22:27:23 +0100
No you are right, it is not possible to do an elimination on o:A\/B
in order to build a proof of (P o):Set.
The distinction between Prop and Set is that the computation
of objects in Set does not need information on object in sort Prop.
In your rule you will have
o:A\/B    f1:(x:A)(P (or_introl x)) f2:(y:B)(P (or_intror y))
  Case o of (or_introl x) => (f1 x) | (or_intror x) => (f2 y) end :(P o)
Because (P o):Set one needs to be able to compute
but without knowing the proof of A\/B which has type Prop, it is not
 possible to choose between f1 or f2
C. Paulin
Patricia Peratto writes:
 > Than you very much.
 > But I want to define dependent elimination over Sort
 > Set. I couldn't. Is not allowed?
 > Patricia Peratto
 > ----- Original Message -----
 > From: "Christine Paulin"
 > <Christine.Paulin AT lri.fr>
 > To: "Patricia Peratto"
 > <pperatto AT hotmail.com>
 > Cc:
 > <coq-club AT pauillac.inria.fr>
 > Sent: Sunday, March 23, 2003 1:48 PM
 > Subject: Re: [Coq-Club] dependent types
 > > You may use the following declaration
 > > Coq < Scheme or_elim := Induction for or Sort Prop.
 > > or_elim is recursively defined
 > > Coq < Check or_elim.
 > > or_elim
 > >      : (A,B:Prop; P:(A\/B ->Prop))
 > >         ((a:A)(P (or_introl A B a))) ->
 > >         ((b:B)(P (or_intror A B b))) ->(o:(A\/B))(P o)
 > > In order to use it, when p has type (A\/B)
 > > there is the tactic
 > > Elim p using or_elim.
 > > C. Paulin
 > > Patricia Peratto writes:
 > >  > I'm trying to define a rule for or_elim with dependent types
 > >  > as follows:
 > >  > (A,B:Prop; P:(A\/B->Set))
 > >  >  ((a:A)(P (or_introl A B a)))
 > >  >  ->((b:B)(P (or_intror A B b)))->(p:(A\/B))(P p)
 > >  > with cases, but does not recognize p as formed
 > >  > by constructors and asks type (P p) for the conclusion.
 > >  > Is it not possible to define this rule in Coq?
 > >  > Regards
 > >  > Patricia Peratto
 > >   Christine Paulin-Mohring             mailto :
 > > Christine.Paulin AT lri.fr
 > >   LRI, UMR 8623 CNRS, Bat 490, Université Paris Sud,   91405 ORSAY Cedex
 > >   LRI   tel : (+33) (0)1 69 15 66 35       fax : (+33) (0)1 69 15 65 86
