- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Resoltuion second-ordre and conversion type
- Date: Mon, 31 Mar 2003 17:27:13 +0200 (CEST)
Bonjour,
J'ai ecris cette petite axiomatization (en changeant mon ancienne) mais j'ai
maintenant
des problemes " Cannot solve a second-order unification problem" et puis plus
tard des problemes
de conversion de termes.
Voici donc l'axiomatisation:
Require Export ProgInt.
Require ZArith.
Require Bool.
Require Bool.Sumbool.
Require Omega.
(* ***** Parameters given by the BSMLlib library ***** *)
Parameters bsp_p:unit -> Z;
Vector : Set -> Set;
at: (T:Set) (Vector T) -> (i:Z) `0<=i<(bsp_p tt)` -> T;
mkpar : (T:Set) (Z -> T) -> (Vector T);
apply : (T1,T2:Set) (Vector (T1 -> T2))
-> (Vector T1) -> (Vector T2);
put : (T:Set)(Vector (Z -> (option T)))
-> (Vector (Z -> (option T)));
ifat : (T:Set) (Vector bool) -> Z -> T -> T -> T;
super : (T1,T2:Set) (unit -> (Vector T1))
-> (unit -> (Vector T2)) -> ((Vector T1)*(Vector T2)).
(* ***** Axiom for the number of processes ***** *)
Axiom good_bsp_p:`0 < (bsp_p tt)`.
Definition within_bound: (i:Z) {`0<=i<(bsp_p tt)`}+{~`0<=i<(bsp_p tt)`}.
Intros; Case (Z_le_dec `0` i); Intros.
Intros; Case (Z_lt_dec i (bsp_p tt)); Intros; Auto.
Intuition.
Intuition.
Defined.
(* ***** Axiom of the asynchronous operators ***** *)
Axiom mkpar_def: (T:Set) (f:Z -> T)(i:Z) (H:`0 <= i < (bsp_p tt)`)
(at T (mkpar T f) i H)=(f i).
Axiom apply_def: (T1,T2:Set) (V1:(Vector (T1 -> T2)))
(V2:(Vector T1 )) (i:Z) (H:`0 <= i < (bsp_p tt)`)
(at T2 (apply T1 T2 V1 V2) i H)=( (at (T1->T2) V1 i H) (at T1 V2 i H)).
(* **** Axiom of the communication-synchronisation operator *** *)
Axiom put_def: (T:Set)(Vf:(Vector (Z -> (option T))))
((at (Z->(option T)) (put T Vf) i H)=([j:Z]
if (within_bound j) then [H1]((at (Z-> (option T)) Vf j H1) i)
else [H2](None T))).
(* ***** Axiom of the global synchronisation construction ***** *)
Axiom ifat_def: (T:Set)(V:(Vector bool)) (n:Z)(R_IF,R_ELSE:T)
(Hyp_n: `0 <= n < (bsp_p tt)`) ((ifat T V n R_IF R_ELSE)=
(if (sumbool_of_bool (at bool V n Hyp_n)) then [H1] R_IF
else [H2] R_ELSE)).
(* ***** Axiom for the parallel superposition ***** *)
Axiom super_def: (T1,T2:Set) (v1: unit -> (Vector T1))
(v2: unit -> (Vector T2)) (super T1 T2 v1 v2)=((v1 tt),(v2 tt)).
Hints Resolve good_bsp_p mkpar_def apply_def put_def super_def: datatypes
v73.
Ce que j'ai actuellement modifier et le fait que pour "at", il faille une
preuve
que l'entier soit compris entre `0<=i<(bsp_p tt)` (ce qui peut paraitre
normal).
Mais cette ajout me pose maintenant des probl�mes inatendus...
Voici donc le developpment d'un programme:
(* des trivialite *)
Lemma egal_some: (T:Set)(a,b:T) ((Some ? a)=(Some ? b)) -> (a=b).
Intros.
Inversion H;Auto.
Qed.
Lemma some_egal:(T:Set)(a,b:T) (a=b) -> ((Some ? a)=(Some ? b)).
Intros.
Induction H;Auto.
Qed.
Lemma egal_reflexive: (T:Set)(a,b:T) (a=b)->(b=a).
Intros.
Rewrite H;Auto.
Qed.
(* Petite expression qui me sert souvent *)
Definition replicate : (T:Set)(a:T) {res: (Vector T) | (i:Z) (Hyp_i:`0 <=i <
(bsp_p tt)`) (at T res i Hyp_i)=a}.
Intros.
Exists (mkpar T ([pid:Z]a)).
Intros.
Rewrite mkpar_def;Auto.
Defined.
(* Idem *)
Definition parfun : (T1,T2:Set)(f:T1->T2)(v:(Vector T1)) {res: (Vector T2) |
(i:Z) (Hyp_i:`0 <=i < (bsp_p tt)`) (at T2 res i Hyp_i)= (f (at T1 v i
Hyp_i))}.
Intros.
Refine Cases (replicate ? f) of
(exist p h) => (exist ? ? (apply ? ? p v) ?) end.
Intros.
Rewrite apply_def;Auto.
Rewrite (h i Hyp_i);Trivial.
Defined.
Et donc le programme principal:
Definition bcast_direct_tmp: (T:Set)(root:Z) (Hyp_root:`0<= root < (bsp_p
tt)`) (vv:(Vector T))
{res:(Vector (option T)) | (i:Z) (Hyp_i:`0 <=i < (bsp_p tt)`) ((at (option
T) res i Hyp_i)=(Some T (at T vv root Hyp_root))) }.
Intros.
Refine let tosend=(mkpar (T->Z->(option T)) ([pid:Z][v:T] if (Z_eq_dec pid
root) then [H1] ([dst:Z](Some T v))
else
[H2]([dst:Z](None T)) ))
in let recv=(put T (apply T (Z->(option T)) tosend vv))
in Cases (replicate Z root) of
(exist p h') => (exist ? ? (apply Z (option T) recv p) ?)
end.
Intros.
Rewrite apply_def; Auto.
Unfold recv.
Rewrite put_def;Auto.
Case (within_bound (at Z p i Hyp_i));Intros;Auto.
Unfold tosend.
Case (Z_eq_dec (at Z p i Hyp_i) root) ;Intros.
Nous avons donc en resumer:
root : Z
Hyp_root : `0 <= root < (bsp_p tt)`
vv : (Vector T)
p : (Vector Z)
i : Z
Hyp_i : `0 <= i < (bsp_p tt)`
a : `0 <= (at Z p i Hyp_i) < (bsp_p tt)`
e : `(at Z p i Hyp_i) = root`
(Some T (at T vv (at Z p i Hyp_i) a))
Donc avant, je faisait "Rewrite e;Auto" et j'avais finis.
Mais maintenant j'ai:
Rewrite e.
Error: Cannot solve a second-order unification problem
Pourquoi ?
Est-ce le fait que "a" soit une preuve pour "(at Z p i Hyp_i)" et pas pour
"root" ?
Pour ne plus avoir ce probleme, je fais donc:
Generalize (egal_reflexive ? ? ? e);Intros.
NewInduction H.
et j'obtient:
T : Set
root : Z
vv : (Vector T)
p : (Vector Z)
h' : (i:Z; Hyp_i:`0 <= i < (bsp_p tt)`)`(at Z p i Hyp_i) = root`
i : Z
a : `0 <= root < (bsp_p tt)`
e : `root = root`
(Some T (at T vv root a))=(Some T (at T vv root Hyp_root))
Or "a" et "Hyp_root" sont de meme types et peuvent donc servir pour les meme
choses.
Comment maintenant prouver cette egalite ?????
Est-ce possible ?
Peut on remplacer "Hyp_root" partout par "a" ?
Merci.
Frederic Gava
- [Coq-Club] Resoltuion second-ordre and conversion type, Frederic GAVA
