- From: "RULE'03 workshop" <giavitto AT lami.univ-evry.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] CFP for RULE 2003
- Date: Mon, 31 Mar 2003 23:43:41 +0200
*** RULE 2003: RPD workshop ***
*** JUNE, 9, 2003 ***
*** Valencia, Spain ***
*** http://www.dsic.upv.es/~rdp03/rule/ ***
IMPORTANT DATE: April 6th 2003 - Submission of full paper
Scope:
The rule-based programming paradigm is characterized by the repeated,
localized transformation of a shared data object such as a term,
graph, proof, or constraint store. The transformations are described
by rules which separate the description of the sub-object to be
replaced (the pattern) from the calculation of the
replacement. Optionally, rules can have further conditions that
restrict their applicability. The transformations are controlled by
explicit or implicit strategies.
The basic concepts of rule-based programming appear throughout
computer science, from theoretical foundations to practical
implementations. Term rewriting is used in semantics in order to
describe the meaning of programming languages, as well as in the
implementation of program transformation systems. It is used
implicitly or explicitly to perform computations, e.g., in
Mathematica, OBJ, or ELAN, or to perform deductions, e.g., by using
inference rules to describe or implement a logic, theorem prover or
constraint solver. Extreme examples of rule-based programming include
the mail system in Unix which uses rules in order to rewrite mail
addresses to canonical forms, or the transition rules used in model
checkers.
Rule-based programming is currently experiencing a renewed period of
growth with the emergence of new concepts and systems that allow a
better understanding and better usability. On the theoretical side,
after the in-depth study of rewriting concepts during the eighties,
the nineties saw the emergence of the general concepts of rewriting
logic and of the rewriting calculus. On the practical side, new
languages such as ASM, ASF+SDF, BURG, Claire, ELAN, Maude, and
Stratego, new systems such as LRR and commercial products such as Ilog
Rules and Eclipse have shown that rules are a useful programming
tool.
The practical application of rule-based programming prompts research
into the algorithmic complexity and optimization of rule-based
programs as well as into the expressivity, semantics and
implementation of rules-based languages.
The purpose of this workshop is to bring together researchers from the
various communities working on rule-based programming to foster
fertilisation between theory and practice, as well as to favour the
growth of this programming paradigm.
We solicit original papers on all topics of rule-based programming,
including but not restricted to
* Languages for rule-based programming
o Expressivity
o Semantics
o Implementation techniques
* Applications of rule-based programming
o Analysis of rule-based programs
o Programming methods
* Environments for rule-based programming
o (Partial) Evaluation
o Abstract machines for rewriting
* Combination of rule-based programming with other paradigms
* System descriptions
Submission procedure and publication:
Submission process will be open in April 2003. Papers (of at
most 15 pages) should be submitted electronically as PostScript
or PDF files to one of the program committee chairs:
- Jean-Louis Giavitto
(giavitto AT lami.univ-evry.fr),
or
- Pierre-Etienne Moreau
(Pierre-Etienne.Moreau AT loria.fr).
The message should also contain a text-only abstract and author
information.
Accepted papers will be published and available during the
workshop. After revision, final copies of the accepted papers
will be published in Electronic Notes in Theoretical Computer
Science (ENTCS), Elsevier Science.
In addition, a selection of best papers could be published in a
special issue of Higher-Order and Symbolic Computation.
Program committee co-chairs:
Jean-Louis Giavitto, Evry Val d'Essone University, France
Pierre-Etienne Moreau, LORIA-INRIA Nancy, France
Program Committee members:
James Cordy, Queen's University at Kingston, Canada
Olivier Danvy, BRICS, Denmark
Steven Eker, SRI International, USA
Thom Fruehwirth, Ulm University, Germany
Berthold Hoffmann, Bremen University, Germany
Herbert Kuchen, Muenster University, Germany
Oege de Moor, Oxford University Computing Laboratory, England
Przemek Prusinkiewicz, Calgary University, Canada
Patrick Viry, ILOG, France
IMPORTANT DATES
April 6th 2003 Submission of full paper
May 5th 2003 Notification
May 14th 2003 Final version due
June 9th 2003 RULE 2003
- [Coq-Club] CFP for RULE 2003, RULE'03 workshop
