- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Lack of functionality for the Pattern tactic.
- Date: Fri, 04 Apr 2003 14:46:47 +0200
Here is a simple example of proof where I have to do something
manually that is cumbersome. I would expect the Pattern tactic to do
it for me, but I did not find the right combination of arguments.
Does anybody know a way to use the Pattern tactic so that the
goal is naturally replace by a goal of the form:
(P intzero (int_discr' intzero))
where P is the proposition given below?
If not, could Coq be extend in such a way that this would be possible?
Variables int : Set; intone : int; intzero : int.
Hypothesis I0_neq_I1 : ~intzero = intone.
Inductive int_discr_type : int -> Set :=
is_zero : (int_discr_type intzero)
| is_one : (int_discr_type intone)
| is_other : (x:int)~x=intzero->~x=intone->(int_discr_type x).
Theorem intone_eq : intone = Cases (discr_int' intzero) of
is_zero => intone
| is_one => intzero
| (is_other _ _ _) => intzero
end.
Cut intzero=intzero.
Apply
int_discr_type_ind
with
P:=
[x:int; v:(int_discr_type x)]
x=intzero
->intone
=Cases v of
is_zero => intone
| is_one => intzero
| (is_other x _ _) => intzero
end;Intuition.
Intuition.
Qed.
- [Coq-Club] Lack of functionality for the Pattern tactic., Yves Bertot
