coq-club - Re: [Coq-Club] Simple question about Module extraction
chronological Thread
  • To: David Pichardie <david.pichardie AT irisa.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Simple question about Module extraction
  • Date: Wed, 11 Jun 2003 14:01:21 +0200 (MEST)
On Tue, 10 Jun 2003, David Pichardie wrote:
> Hi,
> I don't manage to extract module. Here is a simple example :
> ---- coq file ---
> Module Bob.
> Definition t:=nat.
> Definition x:t := O.
> End Bob.
> Extraction Module Bob.
> ---- end coq file ---
> Ok but now, where is Bob.ml ?
> Best regards,
> David.
Ok, it's not a bug, but a really inadequate feature. I have already
had some feedback like yours concerning Extraction Module not working.
The trouble is that Extraction Module come from a time where a Coq
module can only be a *.v(o) file. The semantics of Extract Module foo_bar
was to take the whole contain of a foo_bar.vo, extract it, and put it in
foo_bar.ml.
In your example, Bob isn't a *.vo, so it does nothing (strange it doesn't
complain...)
The workaround for Coq 7.4 is either:
- to extract something INSIDE the module. Then the whole module will be
extracted. Here you can do a 'Extraction "bob.ml" Bob.x'. Dirty, isn't it?
- to put your module in a toto.v file, compile toto.v, and in a new
session, do a 'Require toto. Extraction Module toto.' This will produce a
toto.ml with module Bob inside.
I apologize for this mess, but the fact is that extraction of Coq new
modules was ready only a few days before the 7.4 release, so I hadn't have
time to make them user-friendly. I'm currently working on it (changing
command names and/or semantics).
Pierre Letouzey
