- From: Christine Paulin <Christine.Paulin AT lri.fr>
- To: Jean-Christophe.Filliatre AT lri.fr (Jean-Christophe Filliatre)
- Cc: S�bastien Hinderer <Sebastien.Hinderer AT ens-lyon.fr>, Coq <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Mutually dependent records
- Date: Wed, 9 Jul 2003 14:35:15 +0200
The point is that a record structure is usually supposed to be non
recursive. A recursive record is often empty
(except if the recursive argument of the constructor has a functional
type), and should rather be defined co-inductively.
I strongly recommand to avoid the record structure in that case and
use the alternative (Co)Inductive syntax
C. Paulin
Christine Paulin-Mohring mailto :
LRI, UMR 8623 CNRS, Bat 490, Université Paris Sud, 91405 ORSAY Cedex
LRI tel : (+33) (0)1 69 15 66 35 fax : (+33) (0)1 69 15 65 86
- [Coq-Club] Mutually dependent records, Sébastien Hinderer
- Re: [Coq-Club] Mutually dependent records,
- Re: [Coq-Club] Mutually dependent records, Christine Paulin
