coq-club - Re: [Coq-Club] Pb with Cases and False
chronological Thread
  • To: Jean-Yves Vion-Dury <jean-yves.vion-dury AT inrialpes.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Pb with Cases and False
  • Date: Tue, 29 Jul 2003 12:39:04 -0400
  • Organization: Yale University
Hi,
(n=m) is of type "Prop", which is not Inductive, so doing "Cases" on it has no point -- the "True" in your expression below would be taken to be a variable, not the name of a constructor, and so would "False", hence it is redundant. What you really want is:
Require EqNat.
Cases (beq_nat n m) of true => ... | false => ... end.
Note, (beq_nat) is of type "nat -> nat -> bool" where "bool" which is inductively defined:
Coq < Print bool.
Inductive bool  : Set :=  true : bool | false : bool
See the "EqNat" standard library for converting also proofs from "(beq_nat n m)=true" to "n=m".
--- nadeem
Jean-Yves Vion-Dury wrote:
Dear all,
I'm learning Coq (v7.4), and have a problem with a  "Cases" statement:
Cases (n=m) of True => ...  |  False => ... end.
The problem is with the False => ... branch, that triggers an error message:
>  This clause is redundant
I supect a problem with the "void" definition of False, but how can I do an equivalent
statement ?
Any help appreciated, and thank to the team and contributors for the great job they
accomplished.
Jean-Yves Vion-Dury <http://www.xrce.xerox.com/people/vion-dury/home.html> Research Scientist Xerox Research Centre Europe
INRIA (sabbatical)
655 avenue de l'Europe,
38334 Montbonnot (FRANCE)
Jean-Yves.Vion-Dury AT inrialpes.fr <mailto:Jean-Yves.Vion-Dury AT inrialpes.fr> from France: 0 4 76 61 53 83
from abroad: +33 4 76 61 53 83
you may have a look at the Circus Transformation Language? www.alphaAve.com <http://www.alphaAve.com>
