- From: Pierre Courtieu <Pierre.Courtieu AT sophia.inria.fr> (by way of Pierre Courtieu <Pierre.Courtieu AT sophia.inria.fr>)
- To: GANGCHEN5 AT aol.com
- Subject: Re: [Coq-Club] Tactic definition for handling equality
- Date: Thu, 31 Jul 2003 15:27:45 +0200
- Resent-date: Thu, 31 Jul 2003 15:28:11 +0200
- Resent-from: Pierre Courtieu <Pierre.Courtieu AT sophia.inria.fr>
- Resent-message-id: <20030731152811.751c7b45.Pierre.Courtieu AT sophia.inria.fr>
- Resent-to: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
wrote:
> In a message dated 7/31/2003 4:30:05 AM Eastern Daylight Time,
> writes:
> > Can you show the tatic you wrote? Decompeq seems to be what you need.
> Decompeq is what I need. But it does not work for my example. Maybe there
> is
> a bug in coq. Here is a complete example:
> Variable A : Set.
> Variable x,y,z : A.
> Variable g : A->A.
> Variable g2 : A->A->A.
> Variable B : Set.
> Set Implicit Arguments.
> Variable g3 : (A:Set)B->A->A->A.
> Implicits g3.
> Lemma F_equal_test : x=y->(g3 b z x)=(g3 b z y).
> Intro.
> Decompeq.
> (* Failed :
g3 takes 4 arguments! It works with Decompeq, it should also work with
your tactic if you add cases to it.
> My tactic is as follows, it failed in the last example too.
> Tactic Definition F_equal :=
> Match Context With
> [ |- (?1 ?2) = (?1 ?3) ] ->
> Apply f_equal with f:=?1
> | [ |- (?1 ?2 ?4) = (?1 ?2 ?5) ] ->
> Apply f_equal with f:=(?1 ?2)
> | [ |- (?1 ?2 ?4) = (?1 ?3 ?4) ] ->
> Apply f_equal with f:=[z](?1 z ?4)
> | [ |- (?1 ?2 ?3 ?6) = (?1 ?2 ?3 ?7) ] ->
> Apply f_equal with f:=[zz](?1 ?2 ?3 zz)
> | [ |- (?1 ?2 ?6 ?3 ) = (?1 ?2 ?7 ?3 ) ] ->
> Apply f_equal with f:=[z](?1 ?2 z ?3)
> | [ |- (?1 ?6 ?2 ?3 ) = (?1 ?7 ?2 ?3) ] ->
> Apply f_equal with f:=[z](?1 ?2 ?3 z).
add one more group with (?1 ?2 ?3 ?6 ?8)
- [Coq-Club] Tactic definition for handling equality, GANGCHEN5
- <Possible follow-ups>
- Re: [Coq-Club] Tactic definition for handling equality, Pierre Courtieu
- Re: [Coq-Club] Tactic definition for handling equality, GANGCHEN5
