- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Coq'Art exercices, extensionality and h-reduction
- Date: Tue, 19 Aug 2003 19:06:19 +0200
- Organization: /home
Hello coqers (?),
I'm learning Coq using the Coq'Art book and found exercise 5.28 (page
172)
particularly difficult. We define f1 : Z_btree -> Z_fbtree and f2 : Z_fbtree
-> Z_btree to be conversion functions between two binary tree
representations. Then one must prove (t:Z_btree) (f2 (f1 t)) = t which is
quite doable and (t:Z_fbtree) (f1 (f2 t)) = t.
This one requires two things:
First, to prove (1) z0=([b0:bool](z0 b0)), you need an h-reduction(/
contraction) axiom as it isn't included in Coq's reduction rules. A "Remark"
in the ref. manual state exactly that, but with no explanation, so I ask you,
why not include it or make it easily accessible ? also, is (1) provable in
Coq without it ?
Second, i ended up with a term of the form :
[b0:bool](z0 b0) = [b0:bool](if b0 then (z0 true) else (z0 false)) which, as
I understand it now (after searching a few hours(!)), requires an
extensionality axiom like: (b:A)((f b) = (g b)) -> ([b:A](f b)) = ([b:A](g
b)) or (b:A)((f b) = (g b)) -> (f b) = (g b) to be proven. The extensionality
problem is not discussed before this exercice so I found it quite mean not to
give any hint, although I may have taken the wrong path in the proof. Anyway,
I'd like to know how experienced users would have solved it.
My solution is attached.
Matthieu Sozeau
Require ZArith.
Inductive Z_btree : Set :=
| Z_leaf : Z_btree
| Z_node : Z -> Z_btree -> Z_btree -> Z_btree.
Inductive Z_fbtree : Set :=
| Z_fbleaf : Z_fbtree
| Z_fbnode : Z -> (bool -> Z_fbtree) -> Z_fbtree.
Section Exercice5'28.
Fixpoint f1 [t:Z_btree] : Z_fbtree :=
Cases t of
| Z_leaf => Z_fbleaf
| (Z_node v l r) =>
let (l',r') = (f1 l, f1 r) in
(Z_fbnode v [b:bool](if b then l' else r'))
end.
Fixpoint f2 [t:Z_fbtree] : Z_btree :=
Cases t of
| Z_fbleaf => Z_leaf
| (Z_fbnode v f) =>
let (l,r) = (f2 (f true), f2 (f false)) in
(Z_node v l r)
end.
Theorem f2f1_eq_id : (t:Z_btree)(f2 (f1 t)) = t.
Proof.
Intros t.
Induction t.
Auto.
Replace (f2 (f1 (Z_node z t1 t0))) with (Z_node z (f2 (f1 t1)) (f2 (f1
t0))).
Rewrite Hrect1.
Rewrite Hrect0.
Trivial.
Unfold f1 ; Unfold f2 ; Trivial.
Qed.
(* FIXME: Where is it defined ? h-reduction is not included in Coq's conv
rules *)
Axiom hreduction : (A,B:Set; f:A -> B) f = [x:A](f x).
Lemma if_app_unused : (A:Set; f:bool -> A)
(b:bool) ((f b) = (if b then (f true) else (f false))).
Proof.
Intros A f b.
Case b ; Reflexivity.
Qed.
Require Classical_Pred_Set.
(* FIXME: How-to prove that ? : seems impossible:
http://www.irit.fr/zeno/sujets/sujets-2003-2004.html *)
Axiom for_all_difficult : (A,B:Set; f,g:A -> B)
(b:A)((f b) = (g b)) -> ([b:A](f b)) = ([b:A](g b)).
Hypothesis b : bool.
Theorem f1f2_eq_id : (t:Z_fbtree)(f1 (f2 t)) = t.
Proof.
Induction t.
Trivial.
Intros z z0 H.
Unfold f1 ; Unfold f2.
Rewrite H ; Rewrite H.
Replace [b:bool](if b then (z0 true) else (z0 false)) with z0.
Reflexivity.
Transitivity [b:bool](z0 b).
Apply hreduction.
Apply (for_all_difficult ? ? z0 ([b:bool](if b then (z0 true) else (z0
false))) b).
Apply if_app_unused.
Qed.
End Exercice5'28.
- [Coq-Club] Coq'Art exercices, extensionality and h-reduction, Matthieu Sozeau
