- From: Jean-Yves Vion-Dury <jean-yves.vion-dury AT inrialpes.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] "Concrete" <-> "Abstract" Sets ?
- Date: Tue, 30 Sep 2003 15:23:29 +0200
- Organization: Inria Rhones-Alpes
Dear Coq'ers,
I have trouble trying to connect to views of sets. The first one is "concretely" defined e.g.
Variable A:Set.
Inductive set:Set := empty: set | item: A -> set -> set.
Then, it is possible to define set related algorithms, e.g set_mem:A->set->bool, set_add, ...
as done in the ListSets standard lib.
Then, let us suppose we would like to characterize these algorithms thanks to a correspondence
to the logical theorie of sets, as found in the "Ensembles" standard library.
In ListSets, a propositional inclusion "set_In" is defined through a Fixpoint, and then a soundness is established
with
Lemma
set_mem_correct1 :(a:A)(x:set)(set_mem a x)=true -> (set_In a x).
But is it possible to relate more directly to the set theory defined in the "Ensembles" standard library, ?
Any idea/help much appreciated
Jean-Yves
Jean-Yves Vion-Dury Research Scientist | Xerox Research Centre Europe |
INRIA (sabbatical) 655 avenue de l'Europe, 38334 Montbonnot (FRANCE) Jean-Yves.Vion-Dury AT inrialpes.fr |
from France: 0 4 76 61 53 83 from abroad: +33 4 76 61 53 83 |
you may have a look at the Circus Transformation Language? | www.alphaAve.com |
- [Coq-Club] "Concrete" <-> "Abstract" Sets ?, Jean-Yves Vion-Dury
- Re: [Coq-Club] "Concrete" <-> "Abstract" Sets ?, Pierre Letouzey
