coq-club - Re: [Coq-Club] OCaml tactics
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] OCaml tactics
  • Date: Fri, 10 Oct 2003 13:34:16 +0200
> --__--__--
> Message: 1
> Date: Thu, 09 Oct 2003 16:36:51 -0400
> From: Nadeem Abdul Hamid
> <nadeem AT acm.org>
> Organization: Yale University
> To:
> Subject: [Coq-Club] OCaml tactics
> Hi,
> How does one go about writing tactics for Coq at the OCaml level? I've
> looked through the /tactics directory in the source distribution but
> don't know really where to get started.
> Maybe a complete example would be helpful. For example, take the simple
> tactic below:
> < Tactic Definition ElimEx hyp var := Elim hyp; Clear hyp; Intros var hyp.
> which applies to a hypothesis of form:
> H: (EX m:nat | P(m))
> < ElimEx H m.
> would result in:
> m: nat
> H: P(m)
> Now, instead of doing this in the toplevel tactic language of Coq, how
> could you write the same tactic in OCaml and what tools do you use to
> load it into the toplevel.
> Thanks for your help,
> --- nadeem
I wrote a few tactics at the Ocaml level, and every time, I did it by
copying and pasting from other examples.  The examples to get
inspiration from are in the contrib/ directory rather than the tactics
directory.
Perhaps an even better solution is to use examples from the users'
contributions.  From a quick check, I gather that the contributions
   cps.tar.gz expceptions.tar.gz fta.tar.gz rational-numbers.tar.gz
(especially the last two) should contain tactics written in ml
Other contributions also contain ml code, but I think that ml code is
extracted from proofs, they do not correspond to tactics.
I hope this helps,
  Yves
PS. To find the contributions that contain ml code, I used the
following command (I use bash).
for i in *.tar.gz ; do tar tfz $i | grep '\.ml' > /tmp/bertot-bidon; if [ -s
/tmp/bertot-bidon ] ; then echo $i ; cat /tmp/bertot-bidon ; fi ; done | less
