coq-club - [Coq-Club] loop in tactic definitions
chronological Thread
  • To: Coq-club <Coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] loop in tactic definitions
  • Date: Tue, 14 Oct 2003 11:35:04 +0200
Hi everybody,
I want to define a tactic which repeats a command a number 'n' of times(both the command and the number are given in arguments)
I tried several ways but no one succeeded...
The first solution using Ltac langage is to use the tactical (do num expr...)
Unfortunately it doesn't work because do expects a natural number and 'a priori' we don't know the type of the argument n:
(**********v8 syntax  :-) ************)
Ltac repeatTac n expTac:= do n expTac.
This definition generates a syntax error as I said before...
Another solution is to define a recursive tactic as follows:
Ltac repeatTacRec n expTac :=
match eval compute in  n with
| [0%N] => idtac
| _ => expTac; repeatTacRec (pred n) expTac
end.
The second solution compiles without any difficulties but I 'm unable to use it :
Example:
Definition toto:forall (a:nat) , a=a .
In this simple example 'repeatTacRec 1%N auto' should solve the goal ...but this is not the case !
Thanks for helping me to understand what's the matter!!
Houda ANOUN
LaBRI
