- From: Jean-Yves Vion-Dury <jean-yves.vion-dury AT inrialpes.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Mutual Inductive Types and Double Recursion
- Date: Mon, 03 Nov 2003 11:16:21 +0100
- Organization: Inria Rhones-Alpes
Dear Coq'ers
I'm using an Inductive type like (greatly simplified...I have more cases)
Inductive XP :Set :=
| void : XP
| slash: XP -> XP -> XP
| qualif: XP -> XQ -> XP
with XQ :Set :=
| false : XQ
| and : XQ -> XQ -> XQ
| leq : XP -> XP -> XQ
The default induction scheme is not adapted, and using
Scheme IIP := Induction for XP Sort Prop with IIQ:=Induction for XQ Sort Prop.
I get the right one (that's great, isn'it ?)
Print IIP.
(P:(XP->Prop); P0:(XQ->Prop))
(P void)
->((x:XP)(P x)->(x0:XP)(P x0)->(P (slash x x0)))
->((x:XP)(P x)->(x0:XQ)(P0 x0)->(P (qualif x x0)))
->(P0 false)
->((x:XQ)(P0 x)->(P0 (not x)))
->((x:XQ)(P0 x)->(x0:XQ)(P0 x0)->(P0 (and x x0)))
->((x:XP)(P x)->(x0:XP)(P x0)->(P0 (leq x x0)))
->(x:XP)(P x)
(P void)
->(P0 false)
->(x:XP)(P x)
Unfortunately, I need more: a double induction principle.
Based on Eduardo Gimenez 's example (c.f. tutorial on recursive types in Coq) which is
applied on nat, I'm trying to generalize a similar double induction scheme for my purpose,
starting from IIP above.
It is especially unclear to me how to quantify the predicates
in mixed hypotheses, e.g. the ones derived from
(x:XP) (P x ) -> (x0:XQ) (P0 x0) -> (P (qualif x x0))
should it be
(x,y:XP) (P x y )-> (x0,y0:XQ)(P0 x0 y0) -> (P (qualif x x0) y)
(x,y:XP) (P x y )-> (x0,y0:XQ)(P0 x0 y0) -> (P x (qualif y x0))
Any help or advice would be welcome.
Jean-Yves
P.S: to coq designers: could such a scheme be automatically generated by an extended
SCHEME command ? does it make sense, as mutual recursive definition are far from
being rare in areas like prog. language modeling ?
Jean-Yves Vion-Dury Research Scientist | Xerox Research Centre Europe |
INRIA (sabbatical) 655 avenue de l'Europe, 38334 Montbonnot (FRANCE) Jean-Yves.Vion-Dury AT inrialpes.fr |
from France: 0 4 76 61 53 83 from abroad: +33 4 76 61 53 83 |
you may have a look at the Circus Transformation Language? | www.alphaAve.com |
- [Coq-Club] Mutual Inductive Types and Double Recursion, Jean-Yves Vion-Dury
