[Coq-Club] Patch for loading verbosely files within coqtop from the command line
chronological Thread
- From: S�bastien Hinderer <Sebastien.Hinderer AT ens-lyon.fr>
- To: Coq <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Patch for loading verbosely files within coqtop from the command line
- Date: Thu, 15 Jan 2004 08:54:28 +0100
Dear Coq users and developers,
It seemed to me it could be useful to be able to specify from the command
line that one wants to load a file in coqtop, but verbosely. This seemed
indeed simpler than running coqtop and then enterening the command :
Loae Verbose f.
In particular, this would permit to benefit from shell history facilities
when one wants to load one file during several consecutive sessions under
coqtop.
However, I didn't find any way to do that properly in Coq v8.0-beta.
So, I slightly modified Coq sources, and added two new options :
-load-vernac-source-verbose f and its shorter equivalent -lv f.
For me, it works just fine, so I attach the corresponding patch to this
mail.
To apply this patch, do :
cd $COQTOP
patch -p1 < thepatch
And then just recompile Coq with
make world
Coq developpers : if you find the patch useful, I'd be glad to see it
integrated into a future Coq distribution.
Best wishes,
Sébastien.
diff -ur coq-8.0beta/toplevel/coqtop.ml
coq-8.0beta-modified/toplevel/coqtop.ml
--- coq-8.0beta/toplevel/coqtop.ml 2003-12-30 10:56:20.000000000 +0100
+++ coq-8.0beta-modified/toplevel/coqtop.ml 2004-01-15 06:40:08.000000000
+0100
@@ -73,16 +73,16 @@
let set_default_include d = set_include d Nameops.default_root_prefix
let set_default_rec_include d = set_rec_include d Nameops.default_root_prefix
-let load_vernacular_list = ref ([] : string list)
-let add_load_vernacular s =
- load_vernacular_list := (make_suffix s ".v") :: !load_vernacular_list
+let load_vernacular_list = ref ([] : (string * bool) list)
+let add_load_vernacular verb s =
+ load_vernacular_list := ((make_suffix s ".v"),verb) ::
let load_vernacular () =
List.iter
- (fun s ->
+ (fun (s,b) ->
if Options.do_translate () then
- with_option translate_file (Vernac.load_vernac false) s
+ with_option translate_file (Vernac.load_vernac b) s
else
- Vernac.load_vernac false s)
+ Vernac.load_vernac b s)
(List.rev !load_vernacular_list)
let load_vernacular_obj = ref ([] : string list)
@@ -192,9 +192,13 @@
| "-load-ml-source" :: [] -> usage ()
| ("-load-vernac-source"|"-l") :: f :: rem ->
- add_load_vernacular f; parse rem
+ add_load_vernacular false f; parse rem
| ("-load-vernac-source"|"-l") :: [] -> usage ()
+ | ("-load-vernac-source-verbose"|"-lv") :: f :: rem ->
+ add_load_vernacular true f; parse rem
+ | ("-load-vernac-source-verbose"|"-lv") :: [] -> usage ()
| "-load-vernac-object" :: f :: rem -> add_vernac_obj f; parse rem
| "-load-vernac-object" :: [] -> usage ()
diff -ur coq-8.0beta/toplevel/usage.ml coq-8.0beta-modified/toplevel/usage.ml
--- coq-8.0beta/toplevel/usage.ml 2002-11-05 17:59:14.000000000 +0100
+++ coq-8.0beta-modified/toplevel/usage.ml 2004-01-15 06:39:26.000000000
+0100
@@ -34,6 +34,8 @@
-load-ml-source f load ML file f
-load-vernac-source f load Coq file f.v (Load f.)
-l f (idem)
+ -load-vernac-source-verbose f load Coq file f.v (Load Verbose f.)
+ -lv f (idem)
-load-vernac-object f load Coq object file f.vo
-require f load Coq object file f.vo and import it (Require f.)
-compile f compile Coq file f.v (implies -batch)
- [Coq-Club] Patch for loading verbosely files within coqtop from the command line, Sébastien Hinderer
