- To: <coq-club AT pauillac.inria.fr>
- Cc: <coq-club_NS AT pauillac.inria.fr>
- Subject: [Coq-Club] Problem with length of list
- Date: Thu, 22 Jan 2004 20:19:22 +0100
Dear Coq's wizards,
I have two problems in my development. I give here
the code and the two questions.
Thanks very much.
Best regards, Frédéric Gava. Require Export Arith. Require ZArith. Require PolyList. Require Omega. (* number of processes = p *)
Parameter bsp_p:unit->Z. (* Good number of processes *)
Parameter good_bsp_p:`0 < (bsp_p tt)`. Hints Resolve good_bsp_p. Hints Resolve good_bsp_p : zarith. (* Length of a list in Z *) Fixpoint Zlength [T:Set] [l:(list T)] : Z := Cases l of nil => `0` | (cons _ m) => `(Zlength T m)+1` end. (* My parallel vectors as list with the proof that the length is p *) Record Vector [T:Set]: Set := mkVect { val: (list T); Vect_val_cond: `(Zlength T val)=(bsp_p tt)` }. (* nth elements of a list *) Definition at_tmp: (T:Set) (l:(list T)) (pos:Z) `0<=pos<(Zlength T l)` -> T. Intros T l. NewInduction l;Simpl;Intros. Absurd `0 <= pos < 0`;Auto. Auto with zarith. Case (Z_eq_dec pos `0`);Intros. Assumption. Assert `0 <= pos-1 < (Zlength T l)`. Auto with zarith. Apply (IHl `pos-1` H0);Auto. Defined. (* For the vectors *) Definition at: (T:Set) (Vector T) -> (i:Z) `0<=i<(bsp_p tt)` -> T. Intros. Generalize (Vect_val_cond T H);Intro. Assert `0<=i<(Zlength T (val T H))`. Rewrite H1;Auto. Apply (at_tmp T (val T H) i H2). Defined. (* Discriminate a number with the length of a list *)
Definition within_bound_list: (T:Set) (l:(list T)) (i:Z) {`0<=i<(Zlength T l)`}+{~`0<=i<(Zlength T l)`}. Intros; Case (Z_le_dec `0` i); Intros; Intuition. Intros; Case (Z_lt_dec i (Zlength T l)); Intros; Intuition. Defined. (* Now for parallel vectors *)
Definition within_bound: (i:Z) {`0<=i<(bsp_p tt)`}+{~`0<=i<(bsp_p tt)`}. Intros; Case (Z_le_dec `0` i); Intros; Intuition. Intros; Case (Z_lt_dec i (bsp_p tt)); Intros; Intuition. Defined. (* My first function *) (* It is clear and easy to see that the function do not change the length of the list l *) Fixpoint put_tmp [T:Set;l1:(list Z->(option T));i:Z;l:(list
Z->(option T))]: (list (Z->(option T))) :=
Cases l of nil => (nil Z->(option T)) | (cons hd tl) => (cons ([j:Z] if (within_bound_list (Z->(option T)) l j) then [H1]((at_tmp (Z-> (option T)) l j H1) i) else [H2](None T)) (put_tmp T l1 `i+1` tl)) end. (* But the proof ????? *)
(* i.e. for all i,j,l1,l2 the function does not change the length of the list *) Lemma put_tmp2: (T:Set)(l1,l2:(list Z->(option T)))(l:(list Z->(option T)))(i,j:Z) (Zlength (Z->(option T)) (put_tmp T l1 i l))=(Zlength (Z->(option T)) (put_tmp T l2 j l)). Intros. ?????????????
(* My second function *)
(* She takes two lists, and make an application components by components for the elements of the list *) Fixpoint apply_tmp [T1,T2:Set; l1:(list T1->T2); l2:(list T1)]: (list
T2) :=
Cases l1 l2 of nil _ => (nil T2) | _ nil => (nil T2) | (cons hd1 tl1) (cons hd2 tl2) => (cons (hd1 hd2) (apply_tmp T1 T2 tl1 tl2)) end. (* Now proof that the length of the result of the function is the length of one of the arguments *) Lemma apply_tmp_tmp: (A,B:Set) (l1:(list A->B)) (l2:(list A)) {`(Zlength B (apply_tmp A B l1 l2))=(Zlength A l2)`}+{`(Zlength B (apply_tmp A B l1 l2))=(Zlength [(A->B)] l1)`}. Intros. Double Induction l1 l2. Error: No hypothesis l1 in current goal even after head-reduction How prove it ????
Thanks.
Frédéric Gava.
- [Coq-Club] Problem with length of list, Frédéric Gava
- Re: [Coq-Club] Problem with length of list, Hugo Herbelin
- <Possible follow-ups>
- Re: [Coq-Club] Problem with length of list, Frédéric Gava
